Old 02-28-2012, 10:28 PM   #1
motornut
78K & 79C Jimmys
motornut's Avatar
I wanna drop the front
from what i read
2" drop seems less work then 3"
anybody do a drop on the front and leave the rear alone?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-29-2012, 03:03 AM   #2
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
Re: I wana drop the front
with this truck I think it would look ok with just a 2" front drop. The rear looks like it is sagging anyway. it would get rid of your " cali lean" lol
'85 swb
droppedgmc is offline   Reply With Quote
Old 02-29-2012, 03:51 AM   #3
Pop's C-10
Pop's C-10's Avatar
To me, blazer always look lower in tha front..2 (via 1 cut coil) should be enough, unless you going to pop for 3 in spindles
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-29-2012, 05:41 AM   #4
nibs
JRods Garage
nibs's Avatar
Dont cheap your way out by cutting coils... Do it the right way man!
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 02-29-2012, 08:24 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
not gona cut coils(corners)
i like them lower in front,like droppin a V8 on worn V6 coils "look",
tires stuffed up in front,but hated hittin bottom
what i've read 3 involves cutting some "bits".... or rubbing lol
as for the back....new stock leafs sometime
John
Old 02-29-2012, 11:11 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
If done properly with minimal heat cutting coils is a very good way to get the front down on a budget. I suggest cut a half coil if your apprehensive and go from there. You can do a lowering shackle in the rear, but you will have to mod your gas filler tube.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
