Old 02-29-2012, 12:12 AM   #1
doiton3
Lowered front end alignment question
1968 C10 SWB
3" drop springs in front
4" drop springs in back
Rest of suspension stock and tight.
Talked to a local (non-chain) alignment shop today and he seemed to know his stuff related to these older trucks, but he said he might need to put longer front upper A arm bolts in to get the caster around 3.5deg.
Anyone heard of installing a longer bolt?
For some reason it makes me nervous.
doiton3 is offline   Reply With Quote
Old 02-29-2012, 12:22 AM   #2
BMERDOC
BMERDOC's Avatar
Re: Lowered front end alignment question
I dont think I'd install the longer bolt to add more shims. Allow me to plug my Alignment thread (bottom of my post). Chevyrestoguy did a nice write up on what is argueably the best way to gain more caster. Robnolimit has some great info in his "Make it Handle" thread too.
http://67-72chevytrucks.com/vboard/s...d.php?t=501241
http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-29-2012, 02:07 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Longer bolts will work. 4" grade 8. 1/2"
Moving the control arms work also.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 02-29-2012, 08:40 PM   #4
doiton3
Thanks BMERDOC, I has surfed for 2 days and found the Robnolimit thread but not yours, great info.
I am definitely leaning towards moving the lower arm forward 1/2 to 3/4 inch when the weather warms up.
