Diagnosing cruise control problems??
Ok, so here's where I'm at. When I bought my '86 the cruise control diaphragm was busted and missing, also the stalk for the turn signal switch broken. So, I found the needed parts in my local junkyard. I basically pulled the ENTIRE cruise system from another '86 incase I needed extra parts. So, I've installed everything, and.... Nothing... The d@mn thing doesn't work!!!
![]() ![]() Posted via Mobile Device Posted via Mobile Device
Jay Bernard, Thibodaux, LA 1986 SWB Sierra Classic Stock roller 350/700R4 2008 Buick Enclave CXL 3.6 VVT, 6spd auto. PAINFULLY stock... (wife's ride) |
![]() Join Date: Aug 2011
Re: Diagnosing cruise control problems??
Check brake switch adjustment.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
BAD BOW-Silverado XST
I gave up fixing my 83 cruise. I added an aftermarket unit from Rostra. Worth every dime. My 83 factory manual has info. I don't think I have the pages scanned into PDF files. I'll check.
I have checked the brake switch and its good... Wonder how likely it is that my switch is bad?... Or maybe my VSS
#5 | |
and look here: you probably got this one too...or it will be close: http://www.elcaminocentral.com/showthread.php?t=27191
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
PM SENT! Thanks!
#7 | |
keith.seymore@gm.com Thanks in advance - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#8 | |
I could use one of those pms also. thx.
My 83 cruise never worked correctly. Now it is completely dead. Everything has been replaced under the hood, and the steering column stalk is a one year only 83 unique part which is no longer available. Used to be I could engage the cruise but it would disengage on its own unexpectedly, which would cause the gear vendor to rapidly disengage with a big clunk if I had the GV engaged with the cruise at the same time. |
#11 | |
In my experience it could be the cruise switch. It has solid wires instead of stranded and they break. I got another cruise switch and plugged it in without running it through the column to verify it was the switch and it worked. I’ve also seen the modules down by the accelerator pedal go out. You could probably get on for next to nothing at a salvage yard. Good luck.
