Old 02-29-2012, 01:51 AM   #1
amccomb
need new radiator
I am in the process of doing some research, I am having a hard time finding a new radiator for my 66 k10. Anyone have any suggestions?
amccomb is offline   Reply With Quote
Old 02-29-2012, 02:30 AM   #2
Captainfab
60-66 Nut
Re: need new radiator
Have you tried your local auto parts supplier? There are several members here that have had good luck with the aluminum radiators found on ebay. A simple search here should show a couple threads on them.
Old 02-29-2012, 03:18 AM   #3
amccomb
Thats good to know about the ebay radiators, I was kinda thinking they might be a little chincy.
Old 02-29-2012, 07:32 AM   #4
Woogeroo
http://www.completeradiators.com/
Vendors Marketplace here on the forum.
-W
Woogeroo is offline   Reply With Quote
Old 02-29-2012, 10:03 AM   #5
slorio
slorio's Avatar
amccomb:
Read all about it here. Mine came from RockAuto. You will see the details in my post on this link.
Regards,
Steve
New Orleans
http://67-72chevytrucks.com/vboard/s...d.php?t=479431
slorio is offline   Reply With Quote
Old 02-29-2012, 10:19 AM   #6
1963c-10
1963c-10's Avatar
I bought one of the ebay aluminum ones around 3 years ago for my 63 daily driver and have not had any problems with it. Was quite satisfied with the price and quality.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-29-2012, 10:42 AM   #7
geezer#99
geezer#99's Avatar
Do you know there are 2 sizes of rads. A narrow one for the six. About 18" wide. And a wider one for the V8. About 22" wide. Also different mounts. Watch when you go shopping as some vendors only sell the wider one.
Old 02-29-2012, 10:49 AM   #8
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I bought a champion off E bay.
GMR-PERFORMANCE is offline   Reply With Quote
Old 02-29-2012, 10:53 AM   #9
1963c-10
1963c-10's Avatar
Champion was the brand I went with also. I like the cap with the blow off chain. Cant seem to find them aftermarket though....thought that was weird. I've had a bunch of people ask me where I got the cap from.
Old 02-29-2012, 11:39 AM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have a champion also on my LS swap, keeps everything cool in 105 degree temps with AC on and running in the city.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-29-2012, 01:51 PM   #11
benwah
benwah's Avatar
Sometimes old trucks that sit for years the radiator gets plugged. I remove them. empty them. Put the rad cap back on and lay it flat with the openings faceing up. I then fill the rad with white vinagar and let sit for two hours. Rince and repeat. I usually do two wash/soak cycles. Then rinse with a garden hose for a good ten minuets. Good as new then!
benwah is offline   Reply With Quote
Old 03-02-2012, 07:35 PM   #12
amccomb
Thanks guys thats good to know about the two radiator sizes since my truck was oritginally a 6 and is now a unknown small block v8. Does it matter how many core's I go with I guess 3 might be a better idea?
Old 03-03-2012, 01:48 AM   #13
Captainfab
60-66 Nut
A 3 row core with a shroud will cool most small blocks, and even some big blocks.
