house of chevy's
engine id help
Block # 3970010 head # 3973487 can anyone tell me some info on it please thanx
1987 m1028 cucv d30 ![]() 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" ![]() |
Re: engine id help
350 block (no way to tell if it's a 2 or 4 bolt block without pulling the pan), '71 - '72 75cc chamber heads. If the block is also a '71 - '72 casting, it should be a good one. If it's a 4-bolt block, check the 3 center caps, if they have "2482" cast into them, they're nodular, stronger than plain cast iron. Also, check for 010 020 under the timing cover. If you have 'em all, you have the strongest stock block GM built.
Re: engine id help
Heads int ex
1968-72 3973487 350 1.94 1.5 1968-73 3973487 350 2.02 1.6 Engine 1969-79 3970010 350 185 370 2 or 4 car, truck, Vette 1968 3970010 327 - - 2 A http://www.73-87.com/chevy_ids/sbcid2.htm[/URL] This what I found |
house of chevy's
Re: engine id help
Ok so the guy says its a 69 2 bolt main with a 4 barrel quadrajunk on a aluminum intake what cam would u recomend with those heads if i change to my holley 600 and rpm intake its going in my c10 its a daily driver so just tryin to wake it up alil bit nothin crazey thanx
house of chevy's
Re: engine id help
Anyone
house of chevy's
Re: engine id help
No one can help me here
Re: engine id help
You need to post a bit more information - such as:
Stock pistons? Stock rotating assembly How many miles on the engine? Previously rebuilt? What was replaced or upgraded? Cylinder head combustion chamber? 75cc smog heads Transmission type (manual/automatic) Rear end gears and tires diameter vehicle type, weight Intended usage. Your expectations from this engine. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
#8 | |
house of chevy's
Re: engine id help
Answered best of my abbility
Re: engine id help
For a near stock engine I would use Sealed power CS-1014R and HT817 lifters. This a good RV style cam shaft and work well with stock to slightly modified engines. It is also inexpensive (Northern auto parts)
//RF
