Old 02-29-2012, 12:19 PM   #1
kev2809
low n' slo
kev2809's Avatar
Replacement parts for column
hey, i was lookin through the lmc catalog on replacement parts for the steering column (non tilt) for my 67...
i was wanting to clean it up and paint it, and replace the shift lever, turn signal lever, and shifter retainer, shift indicator and pointer housing. well in the catalog, the shifter and turn signal lever both have 67 part numbers, but the indicator retainer and shift indicator only show 71-72. the pointer housing shows the 67-70 model which looks like mine.
can i just use the 71-72 indicator and retainer? and why is there not a 67-70 shown?
this looks like the original column in the truck...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-29-2012, 12:26 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: Replacement parts for column
heres a few pics...
-_--_--_ _________
Old 02-29-2012, 03:57 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Kev, I know a guy in Spring that rebuilds these columns if you would like the contact info
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-29-2012, 10:41 PM   #4
kev2809
low n' slo
kev2809's Avatar
Cool, thanks. I think the internals should be good...it felt tight before i pulled it out
-_--_--_ _________
Old 03-01-2012, 12:21 PM   #5
kev2809
low n' slo
kev2809's Avatar
anyone..?
im thinking of ordering the parts today...seems like the 71-72 should work but would like someone to chime in!
-_--_--_ _________
Old 03-02-2012, 07:54 PM   #6
kev2809
low n' slo
kev2809's Avatar
also noticed this today when i eventually just took it apart..
what would be the reason for someone splicing into this? i believe i will just fix it the right way and tape it up if it doesnt make any problems..but why would it be cut in the first place?
-_--_--_ _________
Old 03-02-2012, 10:40 PM   #7
Shooters_7
I'd like to know who in Spring rebuilds these. I have a 1965 that needs work!
Shooters_7 is offline   Reply With Quote
