![]() Join Date: Sep 2005
Difference in AD Chevy and AD GMC Cab
I have a 1949 Chevy 3100 with a pretty rough cab. I have found a GMC with a much better cab. Are they the same except for the grill and some trim? Also, will the fenders interchange?
Any help will be appreciated. Jim |
Re: Difference in AD Chevy and AD GMC Cab
Front lip of the hood is different too!
Thanks. Is that the only difference?
Jim |
The GMC and Chevys of 55-59 each have an entirely different dash. the AD trucks may be similar. The cabs should interchange regardless of dash differences
Ad cabs are the same from 47-53. 54 and up they changed the dash.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
I'm not sure of the year change, but the earliest cabs in the 47-53 group had a driver side cowl vent door, and beside the dash change in 54, they also went to one piece windshields.
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
Thank you all. I appreciate the information.
Jim |
The cabs them selves will swap without a problem. There is some difference in the trim and the dash but I think you can easily change out the trim to have Chevy trim. The Gauges are a bit different as the GMC has a higher reading oil pressure gauge.
I'm pretty sure that the 47/53 fenders will interchange except that some models of GMC's have a park light below the headlight. This may just take filing in the holes or leaving the park lights in place. The radiator supports are quite a bit different and won't interchange nor will the hood latch panels. |
Inner fenders are also different, my 50 chevy has a passenger side door lock only, my 3 gmc cabs are drivers only locks. Not sure if it was an option or what. Big trucks have the same cab as the 1/2 tons except the cab overs. There is a difference in the filler rubber between the cab and running boards between years also.
Posted via Mobile Device |
47 and 48 also had a bed mounted fuel tank, 47 has a different parking brake
