Old 02-29-2012, 06:01 PM   #1
snaus32
snaus32's Avatar
Fuel lines?
I'm thinking it's time to run new lines on the 67 what has every one else used? Should i go with stainless, braided, or just go with rubber? The lines on now are both metal and rubber and the rubber one are looking pretty rough. I'd hate to burn up my truck after 5 yrs restoring it lol.
snaus32 is offline   Reply With Quote
Old 02-29-2012, 06:14 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fuel lines?
As MUCH steel as possible
John
1999 Toyota Tacoma 4x4
Old 02-29-2012, 06:18 PM   #3
snaus32
snaus32's Avatar
Re: Fuel lines?
thats what i was thinking. Can you buy it in bulk or does it come pre cut?
Old 02-29-2012, 06:49 PM   #4
JJanzen
JJanzen's Avatar
Re: Fuel lines?
Buy 3/8" brake line and fab your own....very easy and you only need to use
(2) small pieces of rubber; between the frame rail piece and the fuel pump and between the gas tank piece and the frame rail. You should be able to go hard line all the way from the fuel pump to the carb. Here's a partial pic of mine.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 02-29-2012, 06:50 PM   #5
webfoot
Re: Fuel lines?
You can get pre-bent stuff from inlinetube.com or most of the truck specific vendors but I'd guess they are just reselling their products. The one upside of ordering from your favorite truck specific vendor is that their website probably won't suck as much as inline tube's. You can also order stainless fuel lines from inline.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 02-29-2012, 06:55 PM   #6
cdowns
cdowns's Avatar
Re: Fuel lines?
summit jegs speedway motors all sell aluminium coils of 20-25 feet for fuel lines
Old 02-29-2012, 06:59 PM   #7
snaus32
snaus32's Avatar
Re: Fuel lines?
Thanks guys!
Old 02-29-2012, 07:07 PM   #8
Gmichael
Re: Fuel lines?
holy smokes, thats an engine bay! nice.
1970 C-10 SWB (350, TH400, one tire fire...)
Gmichael is offline   Reply With Quote
Old 02-29-2012, 08:29 PM   #9
tubbedII
needs more $$$
tubbedII's Avatar
Re: Fuel lines?
Ditto!!! Where did you get those wire looms and what spark plug wires are those? Looks great!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-29-2012, 11:14 PM   #10
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Fuel lines?
metal line is cheap no reason not to use it
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-01-2012, 03:17 AM   #11
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Fuel lines?
My local parts store has some 3/8 steel line in 60" sections for $6. I'll probably go that route and put a fuel filter at the union along the frame.
If you bend your own line, invest or borrow a high qaulity bender... it will make all the difference in how easy a job it is.
Rich
1972 K5 Blazer CST Click HERE
Old 03-01-2012, 08:09 AM   #12
cdowns
cdowns's Avatar
Re: Fuel lines?
not a good idea if running a mechanical fuel pump
Old 03-01-2012, 09:24 AM   #13
mcmlxix
mcmlxix's Avatar
Re: Fuel lines?
I will be running an efi setup for an LQ9 6.0L, about 60 psi constant pressure, regulated at the in tank pump...
Why is it not a good idea for a mechanical pump?
Rich
Old 03-01-2012, 09:29 AM   #14
SS68
SS68's Avatar
Re: Fuel lines?
may i ask why not?
SS68 is offline   Reply With Quote
Old 03-01-2012, 09:50 AM   #15
chopnchaneled
chopnchaneled's Avatar
Re: Fuel lines?
Subcribed
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 03-01-2012, 10:16 AM   #16
cdowns
cdowns's Avatar
Re: Fuel lines?
mechanical pumps are not as efficient sucking thru filters as pushing thru them after the pump is what i've read and seen reported of many TV shows over the years
Old 03-01-2012, 12:14 PM   #17
Shyguy
Junior Member
Shyguy's Avatar
Re: Fuel lines?
Here is what I have found over the years. If you run a fuel filter in the suction line of a mechanical fuel pump you run the risk of vapor lock due to the pressure drop across the fuel filter.
I had a vapor lock problem on a motor home for years before I realized this and removed the fuel filter in the suction line of the mechanical fuel pump.
Some people do run a fuel filter in the suction line of a mechanical fuel pump until the fuel from the gasoline tank clears up of rust and such.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-01-2012, 02:27 PM   #18
dznucks
dznucks's Avatar
Re: Fuel lines?
I just did this to my truck two weeks ago. Spent about $30. Took about an hour.
I got two 60" sections and a 48" section of 3/8" straight, pre-terminated line from Advanced auto. The fittings will be as much if not more than the line. You will need a good bender...one that pulls the tube while it bends it. If you use a cheap bender, you'll crush the line. I also used a double flare tool to reterminate the lines that I ended up cutting to make them shorter.
Make sure you know what size fitting is on your sending unit. Use a straightened out coat hanger or wire to mock up the bends, then use it as a guide to bend the tube.
dznucks is offline   Reply With Quote
