Old 02-29-2012, 06:30 PM   #1
made2drag
made2drag's Avatar
move steering wheel and column towards dash
i was wondering if anyone has ever moved their steering wheel and column towards their dash by taking the whole steering column out and collasping the shaft near the rag joint. i have done it to my automatic 67 column and gained 3 inches and want to know if 73-87 columns can do this also, before i take it out and find out i cant. im assuming they can, but i havent seen anyone do it in their builds.
made2drag is offline   Reply With Quote
Old 02-29-2012, 06:40 PM   #2
made2drag
made2drag's Avatar
Re: move steering wheel and column towards dash
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
this is the FAQ thread i used to do my 67's column. does anyone know if the 73-87 columns can be modified like this? thanks
Old 02-29-2012, 07:12 PM   #3
SSC's76
No No
SSC's76's Avatar
Ive seen it before on the older ones like in the link but not sure if the newer ones can move back.. id like a few inches extra lol but seriously btt im interested.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 02-29-2012, 11:48 PM   #4
nekkidhillbilly
theres a post where they did that to a square on here. youd have to search but i did see it. moved it 2 inches. my only complaint about a square is the steering wheel is right in your gut.
nekkidhillbilly is offline   Reply With Quote
Old 03-01-2012, 03:25 AM   #5
andrewmp6
Wouldn't a smaller steering wheel be easier?
andrewmp6 is offline   Reply With Quote
Old 03-01-2012, 11:33 AM   #6
made2drag
made2drag's Avatar
i do have a smaller one on it, but i mainly wanted the extra reach. it made a huge difference in my 67. its like moving your bench seat back 2 inches
Old 03-01-2012, 11:34 AM   #7
made2drag
made2drag's Avatar
come to think of it, i gained 2 not 3 inches on the 67.
Old 03-01-2012, 11:47 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
I don't know about collapsing the column, but if you don't have a tilt I highly recommend getting one. It made my truck much more comfortable to drive.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-01-2012, 03:55 PM   #9
made2drag
made2drag's Avatar
mine has tilt and a smaller steering wheel....change from stock made a big difference but i still want a little more reach. im thinking i may try collasping the shaft to get the extra 2 inches. may give it a try in the next month or so....before it gets 100 degrees outside....haha
Old 03-01-2012, 03:56 PM   #10
made2drag
made2drag's Avatar
guys, thanks for the comments so far
Old 03-01-2012, 04:44 PM   #11
joe231
joe231's Avatar
I think the limiting factor is going to be the column to dash bracket. It may need some modification...
CHEVY ONLY
Old 03-01-2012, 06:54 PM   #12
made2drag
made2drag's Avatar
good to know, thanks
wish i could find someone who has done it to see what kind of other obstacles i'll face to see if its really worth it
Old 03-01-2012, 11:35 PM   #13
nekkidhillbilly
even then i think the wheel is to close to you
Old 03-01-2012, 11:36 PM   #14
nekkidhillbilly
seems like they had to shorten the part or collapse it and the cut off the bracket and reweld it on up the column like i said its on here on the board i dont think it has any pictures but is on here.
Old 03-01-2012, 11:43 PM   #15
ghettoluxury
ghettoluxury's Avatar
this topic came up not too long ago if i remember correctly the guy put an s10 column in to gain the room needed.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-02-2012, 07:40 AM   #16
Pop's C-10
Pop's C-10's Avatar
No gut, but 6'3'' & i collapsed mine & tha bracket will have to be modded..even with tilt it seems like it crowds you..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-02-2012, 06:02 PM   #17
made2drag
made2drag's Avatar
so just the bracket needs to be modded and the rest bolts back? so unbolt it, place the steering wheel on the ground with the rag joint up, tap the shaft down 2 inches, then bolt it back up after modding the bracket and that's it, right?
Old 03-02-2012, 06:03 PM   #18
made2drag
made2drag's Avatar
hmmm...ok, because it's shorter i guess
Old 03-02-2012, 06:05 PM   #19
made2drag
made2drag's Avatar
yeah, pictures would be best but maybe i can find another thread, but thanks for the input
Old 03-03-2012, 01:19 AM   #20
BaggedRanger
BaggedRanger's Avatar
I just solved that problem by getting a shorter column. I think the one I bought is like 4" shorter than the factory.. The one thing that sucks is that they sent me the wrong column so Monday I get to call them to ship out another one. Either way that is another option that you have..
BaggedRanger is offline   Reply With Quote
Old 03-03-2012, 01:27 AM   #21
Pop's C-10
Pop's C-10's Avatar
I pulled tha rag joint & drilled tha plastic pins..oiled tha shaft...banged it with a hammer a few times..re installed it..unboltted tha column bracket...loosened tha support on tha firewall & slid it down..i'll try & get some specs & maybe pics in tha morning if tha weather holds out..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 03-03-2012, 10:53 AM   #22
made2drag
made2drag's Avatar
cool! thanks and yeah pics would be great!
Old 03-03-2012, 11:04 AM   #23
made2drag
made2drag's Avatar
i just went and looked at my truck.....looks like 2 inches would put my shifter really close to the dash....did you do 1 1/2 or more? do you have an auto? i guess ill see when i see the pics......also, you were able to tap the shaft in while it was on the truck right? does the shaft pivot so you can hit the end and collapse the shaft?
Old 03-03-2012, 11:56 AM   #24
nekkidhillbilly
the one guys is auto on column
Old 03-03-2012, 12:29 PM   #25
made2drag
made2drag's Avatar
im in the garage right now taking pics as i go....i took a bunch of stuff loose and i have the shaft ready to compress....im planning on a how-to if i get it done today
