Old 02-29-2012, 07:46 PM   #1
rruss86
Smile troubled mpg's
i have a 1987 chevy suburban 3/4 with a 454 w/TBI it has a 400 trans and 4.10 gears... mine is used for freeway use.going to shows and cruise nights.. i have 265-35-22 its a 29.3" tire... a few people say bigger tires or new gears... any ideas what i can really do to raise my mpg...
rruss86 is offline   Reply With Quote
Old 02-29-2012, 08:01 PM   #2
Wrecked1982
Wrecked1982's Avatar
Re: troubled mpg's
my 85 k35 454-th400 is a big fuel sucker i swaped the 4.10 for a 3.73 and now im waiting to put it back together to install 31 inches tires and see what it does. but im keeping my fresh rebuilt 350 ready to take the place of the 454
Wrecked1982 is offline   Reply With Quote
Old 02-29-2012, 08:07 PM   #3
mooseknuckles
mooseknuckles's Avatar
Re: troubled mpg's
......swap the 4:10s for 3:73s!
mooseknuckles is offline   Reply With Quote
Old 02-29-2012, 08:27 PM   #4
Goldfinger
Goldfinger's Avatar
Re: troubled mpg's
I second
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-29-2012, 08:41 PM   #5
jhngardner367
jhngardner367's Avatar
Re: troubled mpg's
You can also check on an after-market,programmable chip,for your ecm.They have some I've seen on the tv show TRUCKS!,and they are proven to help.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 02-29-2012, 09:19 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: troubled mpg's
STAY OFF THE GAS PEDAL! Big block + 3spd + 411 gearing = no mpg ever lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-29-2012, 11:09 PM   #7
donut
donut's Avatar
Re: troubled mpg's
x2,
I was told to feel lucky if I got 10 mpg. And that would be downhill, engine off, and a strong tailwind.
Check to see what the newer big blocks are averaging, that'll give you a goal to shoot for.
What's your mileage now? A baseline will help to determine if it's a tune issue or something else, and a course of action. No point in recommending a gear change or OD if a set of plugs would help you.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-29-2012, 11:12 PM   #8
joe231
joe231's Avatar
Re: troubled mpg's
If you spend most of your driving on the highway, you need OD.
But like donut said, make sure your engine is tuned up. I'd also check for trouble codes and a scanner with live data can be handy...
CHEVY ONLY
Old 03-01-2012, 12:01 AM   #9
nekkidhillbilly
Re: troubled mpg's
overdrive is about your only help
nekkidhillbilly is offline   Reply With Quote
Old 03-01-2012, 01:37 PM   #10
kevinr1970
Re: troubled mpg's
How much of a difference is this going to make?
Not arguing; my '85 3/4t Burb has 4.10's and I am thinking 3.73's.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-01-2012, 03:15 PM   #11
rruss86
Re: troubled mpg's
ok so i was thinking of doing the 3.42, but my brother said 3.08 to get 2200 rpm at 65.. but if i keep the 4.10 and go with a 31" tire instead of the 29" tire.. i wouldnt have to change gears.. or would i
Old 03-01-2012, 03:40 PM   #12
tkeduk8r
tkeduk8r's Avatar
Re: troubled mpg's
From my experience to maximize your economy, you need to match your "most cruised at" RPM with the RPM point of your torque curve when it begins to flatten. With a big block that would probably be around 1700-2300RPM I would think. Then knowing that point, use one of the available online RPM calculators to experiment with tire size, transmission final drive ratio, and ring and pinion ratio. I did alot of playing around with this a few years ago on a bet with some of my students that I couldnt get my 74 c10 to 20mpg. We did it (barely) with a well tuned 305, 2004r, 3.73's and 31x10.50 hiway tread tires and 55 mph. Id bet you could get close to 15 if your set up right. My 72 c20 w/402, TH400 and 3.54 can pull 14 at 55-60 with no load and thats with points ignition and worn 120K engine. Hope that adds some insight.
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 03-01-2012, 09:46 PM   #13
donut
donut's Avatar
Re: troubled mpg's
The other thing to consider is cost vs reward.
OD, gear change, even larger tires cost $$. How much are you willing to spend to save a couple bucks at the pump?
