Enjoying left field
Alternate Heaters
Has anybody used an alternate heater setup from another vehicle in their trucks? I'm running a turbo, and don't have room for the fan and heater core housing. I'm not gonna run AC, and don't see the need for an aftermarket setup like Vintage air. There's gotta be an OEM setup that will fit well under the dash and provide good heat.
![]() Join Date: Feb 2001
Re: Alternate Heaters
A bump for you ...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
You can pick up a Summit Racing or Mojave heater for about 200 bucks brand new, compact units that put out very good heat and easier to fit than trying to cobble an oem heat setup into your truck.
Enjoying left field
I've looked at the Mojave heaters, and I'm not really interested. I would rather spend $50 on a setup that I can make look like it was meant to be there.
Enjoying left field
Anybody? What about modifying the heater core box to lay flatter against the firewall?
Ya I'ma keep watching to see what you come up with. My defrost ducts are rigged right now, at some point I want to rip my entire heating setup out and do something else. But the opposite for me, I want it all out of the cab. I don't need a giant box with flaps. Just constant 50/50 defrost and floor. On, or off.
68 GMC C2500 - 305 V6 - 4spd |
Maybe you can get an early square body heater to work. The engine side of the firewall is pretty compact.
not enough hours in the day
I have one out of a 74 that I could get you measurements from if you wanted to see if it would work.
![]() It is cable operated also, you may be able to make the original controller to work. ![]()
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
60-63 Chevy/GMC's had an "Economy heater" that the fan and core mounted under they dash, and only the heater core tubes went into the engine compartment. See post #5 for a picture.
http://67-72chevytrucks.com/vboard/s...economy+heater Good Luck! |
I'd like to see a pic of the "Economy Heater", and how it is mounted.
Dano
![]() ![]() It ain't yours, if you didn't build it! |
GMC's n H.D.'s too!
The only pictures I see on that thread are in post #5, and #51. There are drawings of it on posts #32, and #50 if that helps any.
GMC's n H.D.'s too!
#13 |
Theres a good drawing in post 32, I think I'll try this in my '70
#14 |
GMC's n H.D.'s too!
There are some good pictures in the additional links I posted too.
#15 |
Enjoying left field
Something else I might try is to rebuild the heater core box so the core sits flat against the firewall. I just need to gain 3 or 4 inches.
