Old 03-01-2012, 01:22 AM   #1
Livrat
Member #1049
Livrat's Avatar
Are all utility buckets created equal??
Since no one seemed to want them at the time, I dissected the seats pictured and stashed the tracks, Gave a set to a buddy and sold the drivers side on the parts board,
My buddy came over and asked. "how do these go on" we looked and figure out they were wrong for his seat.. Darn!!
Then sold the drivers tracks to a board member and just found out they did not fit his seats either.. hmmmm..
Does anyone know if they are different between the years like the bench seat tracks?? (bench seat 67/68 tracks are the same, 69/70 same, 71/72 etc..)
Been working on these trucks for over 30 years and am still amazed at what I learn new all the time!!
Livrat is offline   Reply With Quote
Old 03-01-2012, 07:35 AM   #2
Re: Are all utility buckets created equal??
What are they out of? I know they can vary by vehicle. At least Panel tracks are different,I know for sure.
Old 03-01-2012, 11:09 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Those driver brackets look like the ones in my Panel.I can't see the pass ones well enough to tell but Panel Passenger seats were mounted with a bracket that had a pull pin in the rear to allow them to tilt the back and then flip forward.The front pass brackets were a hinged style to allow the flip.The back had a wingnut to allow it to tilt forward.
Just as a side note,the pass seat in the Panels is listed as an option,but every one I have ever seen had one in it and was listed on the SPID.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-01-2012, 11:10 AM   #4
jaros44sr
jaros44sr's Avatar
No, all utility buckets are not the same, as Tim stated....panels seem to sit a bit flatter to the floorboards, no rake in the seat. Plus, those seat bottoms will only mount up to the correct seat tracks. Seems like the differance is in the height of the rear mount of the seat track. I was going to drill the rivets out and just change the rear mount, but the width of the mount in differant to the seat bottom....trucks versus panels
If you need pics or demensions for the truck utility seats, lmk, as i have them in my blazer/jimmy. Might even have some spare parts laying around since i ran into the same problem youre having
All utility seats mount to the floorboard with a -+ 15" ctc hole
Your pass. side looks to have the hinged mount to allow it to tilt forward
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-01-2012, 12:18 PM   #5
Livrat
Member #1049
Livrat's Avatar
These were out of a Blazer, I do know that panel trucks used a different passenger side front outer hinged mount than a burb (its taller due to the flat floor in a panel), Also I do know that 69/70 Blazers have a different passenger side rear mount/latch than 71/72's.
The problem with the passenger side mount off of these seats is they would not even bolt onto my buddies seat bottom.
Please, if possible post up pictures of your utility seats and tracks. I would like to learn the differences..
I will dig out another set of utility seats for a 71 Blazer I have and take some pics of those
Thanks!!
Old 03-01-2012, 12:18 PM   #6
The Panel mounts are longer,IIRC.
Hey Deland,I've seen single seat Panels and the passenger side floor is different. There is no bump up in the floor for the mount. My friend cut that area from a Suburban so he could mount a second seat in his Panel.
Believe it or not,on base Blazers and Jimmys the passenger seat,which would be the utility type,is an option
I only have a driver side Panel seat. Would a picture help?
Old 03-01-2012, 12:31 PM   #7
Livrat
Member #1049
Livrat's Avatar
Thanks Tim,
It looks like your tracks on your Panel drivers seat are different than my Blazers ones
Old 03-01-2012, 04:33 PM   #8
jaros44sr
jaros44sr's Avatar
I think you can tell the differance from the two types by the metal stamping around three sides...these are panel seats i believe
SAFETY FIRST
AS usual, off topic
Jim
Old 03-01-2012, 05:42 PM   #9
Livrat
Member #1049
Livrat's Avatar
Would you happen to have any pictures of the tracks for that seat? Your bottom frame is definately different than mine. (The front mounting point)
Here are a couple of crappy pictures of my 71 Blazer utility seats, the drivers track is the same as the first pictured one.
Old 03-01-2012, 07:06 PM   #10
jaros44sr
jaros44sr's Avatar
Im at work right now, ill look in the morning
SAFETY FIRST
AS usual, off topic
Jim
Old 03-01-2012, 07:13 PM   #11
jaros44sr
jaros44sr's Avatar
These are the correct size seat tracks for utility seats...2 3/4" & 4 1/2" high
SAFETY FIRST
AS usual, off topic
Jim
Old 03-01-2012, 08:38 PM   #12
dave666693
dave666693's Avatar
those are the brackets that came with my '71 utility buckets on the drivers side. What I can't figure out is what flip bracket goes on that seat for the passengers side. I have seen the one with the lever in the back and the lever on the side, neither fit that seat. Did they have a flip bracket?
The flip bracket with the handle on the side fits my '70 blazer. The dimpled bracket is offset towards the passenger door. I will post pics tomorrow.
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 03-01-2012, 09:07 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
I started this thread about the bench seat brackets.
http://67-72chevytrucks.com/vboard/s...d.php?t=510997
I don't know if it will help.
The bracket is the first post are 69-70 bench seat brackets.
Keith
Convert to disc brakes.
Old 03-01-2012, 09:28 PM   #14
Livrat
Member #1049
Livrat's Avatar
Thank you for posting those pictures,
Does the track you have pictured also fit on the bare Panel seat frame?
What has me confused is I took both tracks off of the utility seats pictured in the first post and neither track fits on two different sets of utility seats.
Old 03-01-2012, 10:16 PM   #15
jaros44sr
jaros44sr's Avatar
I dont think so, but i will dismount it and try tomorrow.....
SAFETY FIRST
AS usual, off topic
Jim
Old 03-02-2012, 10:36 AM   #16
dave666693
dave666693's Avatar
1st picture: 1971 utility bucket with correct drivers side bracket. This bracket does not line up on my 1970 Blazer
2nd picture: location for dimpled bracket on 1970 Blazer
3rd picture: correct flip bracket for a 1970 Blazer. Does not fit on the 1971 seats pictured above
4th picture: this is the flip bracket that has the handle in the back. Does not fit the above seats either or the 1970 blazer.
Is there a flip bracket that fits these seats?
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 03-02-2012, 11:47 AM   #17
Livrat
Member #1049
Livrat's Avatar
Dave, I do believe you flip bracket with the handle in the middle is for a sport bucket seat.
Guys, just for reference the flip handle bracket with the side hand that Dave pictured above is the passenger bracket that came off the seats pictured in the very first post. Does anyone have a bracket like that?
The saga continues..............
Old 03-02-2012, 01:19 PM   #18
jaros44sr
jaros44sr's Avatar
SAFETY FIRST
AS usual, off topic
Jim
Old 03-02-2012, 04:41 PM   #19
jaros44sr
jaros44sr's Avatar
Mark, i think youre right, those other flip seat brackets could of come off of sport buckets....
Any other pics? lmk
Sorry i couldnt talk earlier, had to deal with my mothers hospital issues...
SAFETY FIRST
AS usual, off topic
Jim
Old 03-02-2012, 11:06 PM   #20
Livrat
Member #1049
Livrat's Avatar
Tim,
Thank you for posting the picture,
I think I am getting closer to figuring out the differences. Would it be possible for you to measure the bolt hole spacing from front to back so I can compare it with my 71 seats?
Guys.. so far I gather that 67-70 panels/burbs and 69/70 Blazers used the same seats, and 71/72 Blazers use a different one (All utility buckets that is)..
Does anyone have any pictures of 71/72 burb utility seat frames?
Old 03-03-2012, 12:28 PM   #21
dave666693
dave666693's Avatar
there is a set of utility buckets for sale on the Blazer board that show the brackets attached. Those brackets bolt to a '70 Blazer. He doesn't say what year they are though. Good pics though.
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 03-03-2012, 12:36 PM   #22
Livrat
Member #1049
Livrat's Avatar
Dave, I asked him what they came out of. A 1970 Blazer.. looks like those are the ones you need.
Have you pulled back the upholstery on the bottom of your seats to see if they have the holes like the earlier seat frames?
Old 03-03-2012, 10:39 PM   #23
I'll measure the bolt hole span tomorrow and post it. Sorry,I didn't check this thread yesterday or earlier.
Old 03-04-2012, 04:15 PM   #24
dave666693
dave666693's Avatar
I pealed back the cover and the frame is not like the one above.
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 03-04-2012, 11:08 PM   #25
jaros44sr
jaros44sr's Avatar
Thats a good thing, i think your seats could be the more common blazer/jimmy seats
SAFETY FIRST
AS usual, off topic
Jim
