03-01-2012, 01:40 AM | #1 |
HELP! I need some input on this one folks...
I recently started a build on a 65 stepside. I am running a 350 with a HM290 5 speed trans. It has a hydro clutch setup. I mounted the clutch master cylinder on the firewall beside the brake master cylinder, considering I have to use the clutch pedal assembly to actuate the clutch master cylinder. However, after installing the clutch master clinder I took a step back to observe my work, and started thinking...I have plans to do a power disc conversion but the clutch master is so close to the brake master that I now have concerns that I will not be able to fit in a brake booster when I do the disc conversion.
My question - Is anybody running a hydro clutch setup with power disc brakes? If so, what type of clutch master cylinder did you use and where/how did you mount it? I may have overlooked another thread about this topic, if someone could PLEASE just point me in the right direction I would really appreciate it! |
03-01-2012, 01:59 AM | #2 |
Re: HELP! I need some input on this one folks...
Captin fab sells a kit for just this. Looks top notch. Im sure he'll chime in.
Posted via Mobile Device |
03-01-2012, 03:08 AM | #3 |
I think its in this thread scroll through it and look, or PM captainfab:
http://www.67-72chevytrucks.com/vboa...=1#post3257836
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
03-02-2012, 01:29 AM | #4 |
60-66 Nut
Here is what I offer for the '60-'62's
http://www.67-72chevytrucks.com/vboa...d.php?t=362375 I have plans to offer one for the '63-'66's but I just haven't had the time to put one together yet. I have the parts just no time yet. Let me know if you're interested.
