Starter woes
I had it fixed for a couple months. Now I'm throwing in the towel. New flexplate and a new not rebuilt starter and taking it to a mechanic. One thing I learned about starters is Oriylee (spelled wrong on purpose) starters suck. The first $30 rebuilt tore up my flexplate. Then I went to a NEW chinese made starter and the bolts were coming loose that hold the starter together even after using lock tite. Then the replacement broke a tooth off the starter.
I finally had it working great for 2 months and now all of the sudden the flexplate is grinding bad. I must have hit the bad spot. I found out that a SBC will stop in one of three different spots on the flexplate. The paper clip spacing trick seems to be the winner winner chicken dinner and I did add a front brace. Funny, I've had small block chevys now for over 30 years and never had this many problems with starters. I guess the quality of the crap shipped into this country isn't what it used to be. I couldn't even find an ac delco starter unless I went to a dealer reman for $180. I'm sure I'll get it whipped now but dam... ![]() Last edited by rayfinseats; 03-01-2012 at 02:16 AM. |
Re: Starter woes
Paper clip trick?
Re: Starter woes
As a feeler gauge between the gears...
Re: Starter woes
All the small block starters I've bought in the last 5+ years came with a spacer rod to set alignment along with directions on how to use it. I guess I lucked out, no shimming was required.
Re: Starter woes
Ya, I tried that too.
Re: Starter woes
That sucks.
Re: Starter woes
What really sucks is, as I was following the tow truck with my 1990 truck the 700r4 in it went out.
Re: Starter woes
When it rains...it pours
Re: Starter woes
It looks like the starter was just barely contacting the teeth. No shims. The new flexplate and starter seem to mesh really good. The quality of the starter seems to be the issue. The flexplate didn't look too bad except a couple teeth. That must have been where it was slipping. It looked really good as we were spinning it over.
Re: Starter woes
Ivegot the same problem! About to pull my tranny and change my flywheel tommorrow
Posted via Mobile Device |
Re: Starter woes
Problem solved. Will never buy an OREILLLY starter ever again. Junk. Wally mart batteries are also junk. 3-4 of those in the last year. Turned tha last one in for a core. Good riddens. Next time i'll get this starter rebuilt if need be.
78K & 79C Jimmys
Re: Starter woes
pulled my flywheel bout a year ago,found three areas worn
new starter no shims needed,sometimes it starts first bump was wondering how bad it was so i laid them ontop of each other didn't look that bad when in tho
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#13 |
Re: Starter woes
I've heard people have bad luck with wal-mart batteries...
But I've been running the EverStart MAXX batteries in everything I own for over 10 years with no problems what do ever... Strange... Glad you got it fixed!! Posted via Mobile Device
