60-62 3spd manual swappin in a 700r4
Aloha, putting in a 700r4 in 62 s/b my question is what ru guys using for a transmiussion cross member read plenty threads on here about 63 and up ,,can i cut out the cross member for 3sp bell mount cross member without ruining the integerity of the frame? and then fab up or find someone who makes a cross member that will work without e-brake cable interference thx for ur help
#2 | |
Re: 60-62 3spd manual swappin in a 700r4
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
I built my own. You need 3 pieces of flat steel and a tube. I raised the trans with a jack got into where it needed to be put a screw jack under it to prevent it from dropping down.
Drilled on plate for the trans mount, bolted it to the trans left the tube long pushed it into place tacked the mount plate to the tube. welded that in, then cut the ends of the tube at a angle to match the frame with the correct amount remove for plate thickness, bolted back into place. Took me about 1 hour and maybe 25 bucks in raw steel.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
1962 C-10
You'll be fine to cut out the crossmember where the existing bellhousing mounts to. For the rear trans crossmember, we ended up using one from a mid 90's Chevy 4x4 truck, narrowed it to fit the frame and notched out the center to bring the tailshaft down to the correct angle. When I got the truck it had the old school angle iron crossmember...and it had it for probably 20 years.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Mahalo for the good info will keep u all updated
