Old 03-01-2012, 03:28 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Wiring Diagrams for Dome Light & Cargo Light
Men,
Does anyone have their hands on wiring diagrams for a dome light and cargo light? I am thinking about adding a dome light which I just picked up and the junkyard to my 82' as well as a cargo light. Any help would be greatly appreciated.
Mike
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 03-01-2012, 05:54 PM   #2
jhngardner367
jhngardner367's Avatar
Re: Wiring Diagrams for Dome Light & Cargo Light
The courtesy/cargo/dome lights are all on the same circuit.Running along the driver's side,under the door sill plate will be an orange wire,and a white wire.The orange wire goes to the cargo light/courtesy lightswitches, and the white comes out of the switches,to the lights. The cargo/dome/courtesy lights,all ground through their mounting screws.The cargo light should have its own switch,or it will come on any time the dome/courtesy lights do.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-03-2012, 05:54 PM   #3
Motodrew
How come when I increase my dimmer switch to MAX only my floorboard courtesy light comes on. My overhead dome lamp doesn't come on unless I open the doors. Also, I don't think the floorboard courtesy lamp comes on when I open the doors.
'85 Silverado, 4x4, SB 350.
Keep them beavers grinnin' and them wheels a spinnin'!
Motodrew is offline   Reply With Quote
Old 03-03-2012, 08:26 PM   #4
jhngardner367
Motodrew,I don't know what year your unit is..can you post a pic of the controls/light switch? As for the wiring diagram,I'm trying to upload one.Name:  scan0003.jpg
Size:  47.7 KB Hopefully this will help.
Old 03-04-2012, 07:56 PM   #5
Motodrew
It's an '85.
Old 03-04-2012, 08:06 PM   #6
jhngardner367
Ok.Same year as mine.Mine doesn't have tilt/cruise/delay wipers.The headlight knob, when turned LEFT,will come to a stop,and a slight turn more,should turn on the dome lite,without turning on the lower courtesy lites,as it by-passes the cicuit,and feeds direct from the headlite switch. In the left kick-panel,you'll find an orange wire that feeds the door switch.t-off from it,to a toggle switch,and run from the toggle switch,to the cargo light,so it works separately.
