Old 03-01-2012, 04:59 PM   #1
chuckthetruck
chuckthetruck's Avatar
Alternator issues
Hey I am pegging out in the red on the meter on the dash and if it is at 50% then the belt squeals...have tightened all the way but still doing the same....new alternator and no other problems have happened...
chuckthetruck is offline   Reply With Quote
Old 03-01-2012, 07:47 PM   #2
silvereagle07
silvereagle07's Avatar
Re: Alternator issues
What is the tension on the belt? Is the new alternator putting out any voltage? What is the voltage at idle on the battery? then at 2000 rpm at battery? If the belt is squealing its loose. Are you using the same belt as before the new alternator? Is the pulley the same size as the old alternator? Sorry for all the questions but they may help your situation.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-01-2012, 07:58 PM   #3
Gibson
Gibson's Avatar
What does the voltage measure at the battery?
If it is less than 13volts or so you can try the following:
  1. Take the belt off and scuff the pulleys with a bit of sandpaper to take the glaze off of them. Put on a NEW belt and make sure your tension is correct.
  2. Check the pigtail that plugs into the back of the alt and make sure the connections are clean and not frayed. Do the same for the primary charge lead which is on a separate post on the back of the alt.
  3. Take the ground connection off the bracket and clean it thoroughly.
  4. A bad cell in the battery can cause the alternator to not charge, but will show good voltage while at rest.
Gibson is offline   Reply With Quote
Old 03-01-2012, 09:31 PM   #4
86 K-10
86 K-10's Avatar
cant the belt be too tight? seems like i had a similar problem once and it was because i had the belt pulled way too tight...
86 K-10 is offline   Reply With Quote
Old 03-01-2012, 09:48 PM   #5
Gibson
Gibson's Avatar
Too tight can put unnecessary strain on the bearings in your accessories, yes.
