03-01-2012, 05:04 PM | #1 |
turn signal issue..help
i was just driving home from my uncle's house and turned on my turn signal and they dont flash...they just stay on. however it does flash if i turn on the hazards. anyone know what that is?
03-01-2012, 05:23 PM | #2 |
Re: turn signal issue..help
Did they work before? I'd check my turn signal flasher... I'm 95% sure you have a different flasher for the hazards...
I'm sure someone else will have more input...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? |
03-01-2012, 05:25 PM | #3 |
had this saved on my pc....
03-01-2012, 05:35 PM | #4 |
I have to agree .Replace the turn signal flasher,and it should take care of it.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
03-01-2012, 06:10 PM | #5 |
I had this problem, changed the flasher did not help the fuse was blown it should be where the P location is on the diagram above.
To Broke to be Fast |
03-01-2012, 07:30 PM | #6 |
78K & 79C Jimmys
flasher gets my vote,or ground
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-01-2012, 09:21 PM | #7 |
thanks guys...ill have to check out that flasher. are they hard to change? and where exactly is it? was lookin in the workshop manual and it dont show it at all.
03-01-2012, 09:27 PM | #8 |
Swap the flashers around. I believe they are the same between the 2. If the turn signals come back, replace bad flasher. If not look deeper.
Easy to change, just 2 spade connectors on them. Pull them straight out. The diagram vegas80step posted is the fuse block, look there. My '86 has the hazard flasher by the brake pedal, in case the fuse block doesn't have both.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. Last edited by donut; 03-01-2012 at 09:33 PM. Reason: OP posted |
03-01-2012, 10:04 PM | #9 |
78K & 79C Jimmys
my 78
03-01-2012, 10:29 PM | #10 |
03-01-2012, 10:31 PM | #11 |
Same thing happened to me, flasher it was...
03-02-2012, 04:33 PM | #12 |
so problem solved...changed the flasher...turn signals blink again...thanks again guys for your help!
03-02-2012, 04:53 PM | #13 |
I never realized that there were 2 separate flashers for the signals and hazards.
'Course I have never had any issues with mine, so haven't had the need. But still, learn something new every day!
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 |
