Old 03-01-2012, 05:14 PM   #1
jojoman
supercharged
I was just wondering if i can just bola a small super charger to my 383 i really dont know what all it has in the inside of it it name with the truck is camm with vortec heads and headers that us as much as u can say by looking at it
jojoman is offline   Reply With Quote
Old 03-01-2012, 06:13 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: supercharged
Depends on your compression. If your compression is to high you will hav to run race fuel as the supercharger raises the compression a couple points
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-01-2012, 07:42 PM   #3
silvereagle07
silvereagle07's Avatar
Re: supercharged
Agreed ^^^. Stock compression on a vortec 350 is around 9.4. Check out this article on a budget build vortec engine with a supercharger in Car craft. I was toying around with this idea on my engine too.
http://www.carcraft.com/techarticles...d/viewall.html
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-01-2012, 08:07 PM   #4
ringger14
ringger14's Avatar
Re: supercharged
Was just looking in my Weiand book. If the compression is around 9.5-1, using their smallest supercharger at 6 lbs is going to put the compression to about 14.8-1. Itll work if you run the 2 lb boost setup but what would be the point of that haha. You can put power adders on anything you want, but for them to be effective the engine needs to be built for them. Cam, Low compression, forged internals ect.
ringger14 is offline   Reply With Quote
Old 03-01-2012, 09:01 PM   #5
bustedknuckles
bustedknuckles's Avatar
Re: supercharged
Without knowing what's in it would make it hard to know how much you can put on it. Main concern would be camshaft, fasteners, and compression ratio. With the right camshaft you can run more compression with boost. I am running a 9.4:1 vortec headed 383 with 6psi on it and its all setup for 10, so once its broke in I'll be swapping some pullies. I would say do a cam swap if you're gonna do a small blower and set it up with low boost at first and see how it reacts.
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 03-02-2012, 02:22 PM   #6
jojoman
Re: supercharged
Well wen I bought the truck the guy who built the engine told me that everything inside was forged and I know for sure Im using supreme gas other wise is crap wen running and the cam I don't really know what size is it wat cam would ya reccomend to put in it really Im not trying to get anything over 6lbs I just want something to pass up them slow "pony's" how is the compression measured exactly and is there any way to do it now as it is and bustedknuckles um big fan bro saw you at the lonestar really that's why I wanna do It motivation
Old 03-02-2012, 03:07 PM   #7
bustedknuckles
Re: supercharged
I had mine custom ground by cam motion. But to have a cam ground you need to know every single detail about your engine. You can go on summit or jegs site and pick an off the shelf blower cam. IIRC there is a way to measure compression by just checking it with a gauge, but not 100%. If I was you I'd figure out the compression, then pull the camshaft and measure it for lift, bc you don't want to get too big and have interference or valve spring issues.
84 GMCummins
91 CCSB Dually
Old 03-02-2012, 05:10 PM   #8
jojoman
Re: supercharged
So the only correct way to check compression is to take engine a part and find out what all parts I got or wat
Old 03-03-2012, 01:57 AM   #9
andrewmp6
Re: supercharged
I think you can find out with just knowing the bore the stroke and the heads cc.
andrewmp6 is offline   Reply With Quote
Old 03-03-2012, 10:52 AM   #10
C-10 simplex
Re: supercharged
RE: carkraft writeup:
Fine, but what crank, rods, pistons are they using---can the rotating assembly take it? And can a stock block take 450hp/450tq on a regular basis?
C-10 simplex is offline   Reply With Quote
Old 03-03-2012, 10:56 AM   #11
andrewmp6
Re: supercharged
If your looking 5 to 8psi the stock block might hold anything higher then that i would look at a aftermarket block.
Old 03-04-2012, 12:47 AM   #12
rayfinseats
Re: supercharged
I agree. I was gonna say it depends on how much blower pressure you run. Stock pistons don't like blowers much.
"Well wen I bought the truck the guy who built the engine told me that everything inside was forged" HAHAHAHAHA... Of course he did.
rayfinseats is offline   Reply With Quote
