Old 03-01-2012, 08:32 PM   #1
b2kbassman
Emissions Removal 1971 C10
Anyone know if my gas mileage will improve if I remove and block off the vaccum line to the evap cannister? Im running a Crate 350 with std points and a quadrajet. Im currently only getting 10mpg but also don't want to impact performance or damage the engine. Any other suggestions on improving mpg? Thanks!
b2kbassman is offline   Reply With Quote
Old 03-02-2012, 08:10 PM   #2
Eddie H.
Eddie H.'s Avatar
Re: Emissions Removal 1971 C10
It won't make any difference whatsoever in your fuel mileage.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 03-02-2012, 08:27 PM   #3
Lee H
Lee H's Avatar
The best bang for your buck to improve mileage is a real tune-up. New points, plugs, wires, air filter, make sure mechanical and vacuum advance are working right, dial in the timing, professional carb rebuild. Tire pressure check, also make sure your brakes are not dragging. What gears are you running?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-02-2012, 10:17 PM   #4
earlthegoat2
earlthegoat2's Avatar
Hei
That's Medium Gold. You just want to see Ochre.
earlthegoat2 is offline   Reply With Quote
