Old 05-02-2003, 07:08 PM   #1
RShaips
72 Chevy 4WD Truck frame and drivetrain
I have a 72 Chevy 4WD Longbed frame and Automatic drivetrain for sale. I was going to restore this truck but have decided to build a shortbed 2WD.I drove this truck before I took it apart and everything was very tight and it drove excellent.It has new front rotors ,brakes and bearings in the front that I installed, and the guy I bought it from had the Transmission,transfer case and differentials rebuilt,also had new 1 ton leaf springs installed all around and new power steering gearbox.I have all the reciepts for this work. He owned it for 10 years and used it to haul his boat and plow snow.I cleaned the frame and put POR-15 on it and painted over it. The back brakes will need to be replaced. It has nice rally wheels and decent 12.5 x 33 BF Goodrich mud TA's.The motor is not included. I have the title and vin plate for this truck. $1200.00 Thanks
RShaips is offline   Reply With Quote
Old 05-04-2003, 12:18 AM   #2
RShaips
ttt
Old 05-04-2003, 08:35 PM   #3
RShaips
Snowman your mailbox is full ! I have the high hump cover and steering shaft . The fan shroud and the power brake booster,I am keeping for my other truck.Those should be the only things you need to convert a 2WD truck. Thanks
Old 05-07-2003, 10:00 PM   #4
RShaips
ttt
Old 05-11-2003, 12:04 PM   #5
RShaips
Several guys interested but I stll have it !
Old 05-13-2003, 11:04 PM   #6
RShaips
Last time,otherwise I will put it on ebay or part it out. Thanks
Old 05-14-2003, 10:20 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If you part it I'd like to get the power steering gear box.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-27-2010, 12:41 PM   #8
kevin.mcnally
Re: 72 Chevy 4WD Truck frame and drivetrain
do you still have the frame? if so what would you want for just the frame and springs? thanks
kevin.mcnally is offline   Reply With Quote
Old 10-27-2010, 12:56 PM   #9
to the site
I'd think after only 7 years there's a good chance it's still sittin' in the same spot(not) Sorry,I had to say "Holy Old Posts,Batman!" We can always hope,but I'd think sending a pm would be more effective.Chances are the guy doesn't check this thread real often.Don't forget to figure in inflation
ps:Just messin' with ya
