05-02-2003, 07:26 PM | #1 |
drag it like you stole it
XXL.. question about your chop
hows it coming? and are you going to use the stock winshield? how much chop is it? also, how many hours you think you will have in it? thanks
negative camber //LA\\ |
05-02-2003, 07:51 PM | #2 |
Seņor Member
The front is 2 1/4 and the rear is 1 3/4 (or something like that). A-pillars are laid back about 2" at the top, which makes for a larger windshield, but it will still have to be cut down some. The way the rear was cut, the stock glass will fit without cutting .
I'm not sure how long it will take, but I'm starting to chomp at the bit. I'm also going to have suicide doors on the thing, and the doors have 1-piece glass. I'm actually having someone from the board do the chop and doors. I'll give kudos after he's done. Kenneth
