Dual Exhaust: Uneven Flow
I have dual exhaust on my 86. 3" pipes all the way back. No Y pipe no cat converter, only headers, mufflers and pipe. I noticed when it was cold that my left pipe shot out more exhaust than the right. Both work, just its uneven. Is that a problem????
-Samuel "Knowledge Is Power" |
Re: Dual Exhaust: Uneven Flow
not a prob.
if it worries you enough just put an X pipe in there, that will even it out some, and prevent the popping that is associated with revving up a loud motor |
I put a 3 inch x-pipe kit from Jegs in my truck. Made a big difference on the sound, mellowed it out a lot. Has a nice tone driving down the road. As said before, it isnt a problem to have that difference, just depends on how picky you are about the exhaust.
Not a problem. That is showing your heat riser on the right side manifold is working properly and the heat crossover in the intake is clear. It is disigned to work just like that.
You have headers...are all of your wires in good shape? Does it have a miss? When it's cold and you hold your fingers over the outlets does it blow out steadily or are your fingers ever pulled in while running?
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
