Old 03-03-2012, 05:32 PM   #1
pickupman
pickupman's Avatar
Tilt Coulumn Parts
I have a part of a tilt column for parts. have just what you see. $50 + shipping
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 03-04-2012, 03:24 AM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Tilt Coulumn Parts
How is the shifter pin hole?
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 03-04-2012, 01:35 PM   #3
jaros44sr
jaros44sr's Avatar
If the tilt bowl has bearings in it, ill take it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-04-2012, 02:11 PM   #4
pickupman
pickupman's Avatar
Kevin, lever and pin hole are in good cond.
also have a shaft, not sure if it is a truck or van don't have one here to check. It is aprox 39" from end to end
Jaro--no bearings in it
Old 03-04-2012, 03:03 PM   #5
KevsClassics
TILT COLUMN GURU
I'll take it.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 03-04-2012, 03:11 PM   #6
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Originally Posted by KevsClassics View Post
I'll take it.
Great deal!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 03-04-2012, 03:12 PM   #7
pickupman
pickupman's Avatar
Sold to Kevsclassics
Old 03-04-2012, 03:13 PM   #8
HeavyMetalChevy
Just a Member
Are you referring to the steering shaft?
TH400(3rd)
Old 03-04-2012, 04:15 PM   #9
pickupman
pickupman's Avatar
yes the steering shaft that steering wheel bolts to
Old 03-04-2012, 09:27 PM   #10
ls1nova71
ls1nova71's Avatar
A van shaft is about 35 inches long and a truck is about 32 1/2 inches long measured from the splined end to the end where the plastic spheres things go.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-22-2012, 12:48 AM   #11
KevsClassics
TILT COLUMN GURU
Thanks Steve, LMK if you come across more parts.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 03-22-2012, 12:51 AM   #12
HotRod C/10
HotRod C/10's Avatar
good to know!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
