03-03-2012, 06:31 PM | #1 |
1982 Parking Brake Question
I bought this 82 Sierra 3500 with the parking brake assembly not working, it wouldn't stay engaged. With a ton of oiling, it now stays engaged, but I don't have a brake light coming on when it is engaged. There is a brown wire that looks like it is supposed to trip the light on when it is engaged, but I don't see anything to attach it to, there's no switch or anything like that, just the parking brake assembly. Is there supposed to be a switch on the assembly? Any help would be greatly appreciated!
03-03-2012, 09:06 PM | #2 |
Re: 1982 Parking Brake Question
There should be a small black switch on the assembly,with a small tab,that the wire connects to.Test the light,by touching the wire to ground(ignition on)momentarily.If there's no light on,check the bulb,in the cluster.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
03-04-2012, 12:06 AM | #3 |
I dont have one on my 82.
John 82 Chevy Silverado 350ci/TH350 |
03-04-2012, 09:39 AM | #4 |
78K & 79C Jimmys
my 78 no 79s yes
this is 79 4X4 Jimmy shown up next to the hazard flasher
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-04-2012, 09:48 AM | #5 | |
Other way to check the bulb, turn the key to "on" all your dash lights should light, even the 'brake" light. J Knight, You should... even my '73 had one. IIRC it also is a warning light for pressure loss in the system and is triggered off of the proportioning valve. OK read motornut's reply, maybe not all of them had it.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
03-04-2012, 10:01 AM | #6 | |
03-04-2012, 11:51 AM | #7 |
Robert Olson Transport
I have an 82 Scottsdale there is a small switch located on the top of the emergency brake pedal assembly. If i can get down the the garage today ill take a pic of the spare one i have
03-04-2012, 12:01 PM | #8 |
Hey thanks for the replies guys! This is such a great board!
Yeah, I went to the garage this morning, and took a closer look at that assembly. I don't even see where the darn thing would attach to the assembly. I even tested that wire and got nothing when I grounded it, so it may also have a bad bulb. I figure that if it comes down to it, I could probably just mount my own switch to get it to kick on. |
03-04-2012, 12:39 PM | #9 |
1 Switch
1 Mounting Screw 1 Wire Desert |
