Old 03-03-2012, 06:50 PM   #1
thebacon
More '62 Front Suspension Questions
How do you separate the ball joints on the control arms? Tie Bar Rod (big fork) size 21/32 is too small for the upper arm, and the lower arm is even bigger.
thebacon is offline   Reply With Quote
Old 03-04-2012, 01:52 PM   #2
thebacon
Re: More '62 Front Suspension Questions
http://www.craftsman.com/shc/s/p_101...2&blockType=L2
Found what I need, well hopefully it has sizes big enough.
Old 03-04-2012, 03:10 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Good for you and thanks for sharing, it may help the next guy. I had nothing to offer as I never tried to pull mine apart. I yanked the whole thing out as one piece when swapping to a 75 disc brake suspension.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-05-2012, 12:31 AM   #4
doobiebro
doobiebro's Avatar
hit it with a big hammer on the top and bottom spindle area... you wont hurt it..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 03-12-2012, 01:02 PM   #5
thebacon
Used a 15/16ths for the top and a 1-?/? For the lower, out of the kit linked earlier.
Been looking at replacement stuff, I understand ball joints should be replaced, what about the cross shafts?
Ball joints, cross shafts from cpp is 400 dollars total for all four. Then disc brakes for another 500, this sound about typical?
Old 03-12-2012, 09:54 PM   #6
thebacon
Possibly I can get by with just the bushings or how necessary is it to replace the "Control Arm Shaft"/Cross Shaft/ Whatever else its called? Seems like a solid bar and the bushings are the main thing that need replaced?
