Old 03-03-2012, 10:25 PM   #1
UP GRADE
one set closer
UP GRADE's Avatar
Brake light
need a little help. my passanger side brake light is not work check the bulb, socket, and the wiring all good. but the parking lights work fine can anyone tell me what else to check.
UP GRADE is offline   Reply With Quote
Old 03-04-2012, 02:10 AM   #2
peglegs
peglegs's Avatar
Re: Brake light
UP GRADE i recently had the same problem & traced it to the firewall connector i cleaned it up plugged it back in & the lf brake light worked fine i cant say what the relationship was to the lf was & not sure if there is a lf & rt connection there......im happy it works
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 03-04-2012, 05:57 AM   #3
70Custom10Nut
70Custom10Nut's Avatar
Re: Brake light
Ditto peglegs. If you haven't already done so, replace it. The 40 + year old wires my look fine on the outside but the wires will break and separate. This will have you pullin your hair out. Fix it once and you're good for another 50 years.
70Custom10Nut is offline   Reply With Quote
Old 03-04-2012, 08:15 AM   #4
scott-wisc
scott-wisc's Avatar
Re: Brake light
Try playing around with the turn signal with your foot on the brake. I had the same problem and fixed it by spaying electrical contact cleaner into the hole on the stearing column. I'll probably have to replace the switch eventually.
scott-wisc is offline   Reply With Quote
Old 03-04-2012, 08:54 AM   #5
cdowns
cdowns's Avatar
Re: Brake light
run a ground from the socket to the frame// if left brake light works fine there is nothing wrong with your firewall plug
you can also try a new light bulb
Old 03-04-2012, 09:36 PM   #6
UP GRADE
one set closer
UP GRADE's Avatar
Re: Brake light
ok thanks guys i'll give this a try.
Old 03-08-2012, 08:08 PM   #7
UP GRADE
one set closer
UP GRADE's Avatar
Re: Brake light
ok guys put in new bulb, ground it to the frame, check the wiring form the rear to the front all seem to be good anything esle that i need to check?
Old 03-08-2012, 09:20 PM   #8
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Brake light
Do you have a good test light?
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 03-12-2012, 11:25 PM   #9
UP GRADE
one set closer
UP GRADE's Avatar
Re: Brake light
ok found out whats wrong with the brake light. its the the turn signal cam (the thing that move to turn the signal light on) everytime i push in on it and mash the brakes they come on. thanks for everyone help.
