03-03-2012, 11:06 PM | #1 |
frame crossmember
referring to the picture, why is the crossmember curved up? could I just run square stock across he end of the frame rails? I want to use this area to mount a gas tank, and if I just move the crossmember to the rear it would interfere with the bed sill..what if I flipped it upside down under the sill?
http://good-times.webshots.com/photo...02454676xxSCeD |
03-03-2012, 11:19 PM | #2 |
Hollister Road Co.
Re: frame crossmember
Some models had an under bed spare tire.
03-04-2012, 01:12 AM | #3 |
+1 spare tire
yes you can remove. Just be sure to take a measurement cause the frame will want to "spring" in a little...
I ask cuz' I dont know better... 51 Chevy p/u - awaiting parts(cash) |
03-04-2012, 01:16 AM | #4 |
The after...
Note the 2x4 to keep frame spead.
03-04-2012, 08:55 PM | #5 |
I did mine with a tube crossmember in the same location that your 2x4 is in but I put the new crossmember in place before removing the original one. I think replacing the stock crossmember is a pretty standard operation on these trucks when you move the gas tank.
