Old 05-03-2003, 12:13 AM   #1
Adam12
I hate trannys
Adam12's Avatar
ahh! wheel stud problems
It's a new problem every week.....I was driving my truck home today, and noticed as I made a right turn a HUGE knocking sound. So I stopped the truck and looked at the front right side of the truck where the the noise was coming from. I was missing a lug nut and could tell the whole wheel was loose. So I pull the jack out and get ready to tighten the rest of the lug nuts, but they just kept spinning then I tried to take em off and same thing. All 5 studs have broken loose so I cant get my wheel off :/ anyone know any neat tricks to help get it off? and then keep it on? could you tack weld the studs in the back?
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 05-03-2003, 12:44 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
any way you look at it, your current studs are toast. You might get lucky and get a spot weld to hold long enough to get the nuts off, but then you still have to grind the weld down to get the studs out. If you're running drums on front, you can take the hub off, wheel and all and take it to someone who has a torch and cut the nuts off, then drive the studs out, or grind the back side of the studs off and drive them out backwards, hopefully it hasn't wasted your hub to the point that it won't accept new studs.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-03-2003, 04:18 AM   #3
Adam12
I hate trannys
Adam12's Avatar
Thanks. At least now I know what I can do. Looks like its going to be real fun, I have some cheap centercaps on the wheels so i cant get teh hub off unless I cut them open first.....
Old 05-03-2003, 08:04 AM   #4
MOTHERTRUCKERS
Get a nut splitter and split the lug nuts or a good cold chisel and a hammer. I'll bet your wheel is wobbled out to where it's no good so a torch will be the easiest way. I have good used 67-70 hubs for 20.00 if you need one.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
