Old 03-03-2012, 11:33 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
6 Lug Wheel Not Fitting 6 Lug Rotor.
I have been working on my '65 Panel and today I needed to roll it around a little. I used a CPP modular brake kit with 6 lug rotors. The wheels are US Mag slot mag wheels. These were on the original drum brake spindles without any problems.
The problem I am running into is that the studs on the rotor are just slightly off on 3 or 4 of the stud and using mag wheel style lug nuts with the slot mag, I cannot get the nuts to go into the hole and thread on the studs.
Has anyone run into this problem with 6 lug rotors?
I think if I was using steel wheels with standard acorn nuts, there is enough "play" to compensate but with mag lug nuts and wheels, they basically need to be dead one.
Help! BTW, one rotor seems fine but the other one seems to be off.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-04-2012, 02:13 AM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 6 Lug Wheel Not Fitting 6 Lug Rotor.
If one rotor seems fine, and the other one is off, I would think the one that is off needs to be returned to CPP.
To verify the issue is with the one rotor; try swapping the wheels around.
66 C20 Service Truck:
Old 03-04-2012, 02:39 AM   #3
Captainfab
60-66 Nut
I agree. Sounds to me like a defective rotor.
