Old 03-04-2012, 03:42 AM   #1
dmartin1
dmartin1's Avatar
'82 to 70's front swap advice.alignment..
So I bought an entire front clip etc to seal my trucks 82 front clip off.
Anyone got advice on aligning the body parts on when I get it on? Never done this before but know the basicss.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 03-04-2012, 04:48 AM   #2
sethv
sethv's Avatar
Re: '82 to 70's front swap advice.alignment..
Always use shims whenever possible, they make your life easier. Also, do not tighten the bolts all the way down till you're happy with how it is aligned. Tighten them snug, so they don't move easily, but can still be shifted around if you move it. When you're happy then go ahead and tighten them down. Also, use anti seize on the threads of the bolts.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
