03-04-2012, 11:09 AM | #1 |
Spindle issue
When I was re-assembling my front end I somehow ended up cross threading one of my brake caliper bolts and the threads in the spindle are shot. I am thinking I may be able to get the correct tap and clean them up. Anyone have any experience with this or have any other ideas? 77 C10 2wd.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
03-04-2012, 11:26 AM | #2 |
Re: Spindle issue
Yes I had the same issue, I didnt want to mess with it so I bought another set of spindles. I gave my damaged set to my neighbor, he took it to a machine shop to get it fixed. They drilled out 3/4in hole and either welded or pressed in an insert, using the other good spindle as a template or guide they drilled a new hole and tapped it. We then installed them on his truck and they fit perfect.
Oh yea it was $45 to fix it.
John 82 Chevy Silverado 350ci/TH350 |
