Old 03-04-2012, 02:03 PM   #1
Greshampiglet
Installed My Fuel Cell
Just got done installing my 20gal fuel cell, just have to plumb it, and wire it, and take the old gas tank out YEAH!!!
GreshamP1GLET
Greshampiglet is offline   Reply With Quote
Old 03-04-2012, 02:51 PM   #2
Wolfinthesnow
Wolfinthesnow's Avatar
Re: Installed My Fuel Cell
Wow man that looks killer!! Where did you pick up the tank from?
I dont care how you did it in California!!!
Wolfinthesnow is offline   Reply With Quote
Old 03-04-2012, 11:13 PM   #3
Greshampiglet
Got the fuel cell from Brokendickracing.com
cost was $219. 20GAL
GreshamP1GLET
Old 03-04-2012, 11:19 PM   #4
ozzyman
ozzyman's Avatar
Wow, what was required to install it? I see the traps on top but what about anything supporting it from underneath? Fuel sender came with it?
did you use their mounting kit?
ozzyman is offline   Reply With Quote
Old 03-05-2012, 10:42 PM   #5
Greshampiglet
The bottom straps are of a 78' blazer and run left to right only had to drill one extra hole for the straps. I was going to put the gas tank out of the 78' also but because I have a short box it was to big I took the rear support bracket out and replaced it wit 3 1/2" channel and moved back 3"
GreshamP1GLET
Old 03-06-2012, 10:56 AM   #6
el_bole
I want a similar set up on my '73 frame. What parts does one need to buy to "plumb" it? I've been looking at sites like ebay etc. and havent found a kit per se to hook these cells up. Thanks
el_bole
P.S. You metioned that you used a '78's straps for the left to right support of fuel cell, do you have pics? Any welding involved?
el_bole is offline   Reply With Quote
