SUCCESS!!! BBC Valve Seal Replacement!
I successfully replaced a intake valve seal with the head still on the engine! I did it the traditional way with a valve spring compressor and a piece if rope! I didn't realize how easy it was but I still only replaced the one, the best part is the BBC doesn't smoke anymore!
Re: SUCCESS!!! BBC Valve Seal Replacement!
Ya, I have to get around to doing mine also. Did you use the umbrella type seals? Aprox. how long does it take? I have an 87 454 TBI, It's my daily driver, so I'd have to make it a week end job.
What is the trick with the rope?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
You pull the spark plug and fill the cyl full of rope to hold the valve up.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
#5 | |
![]() Join Date: Apr 2009
http://67-72chevytrucks.com/vboard/s...19#post5167719 Desert PS: Good Job! |
From start to finish it took around 30 minutes to replace one umbrella style valve seal! The trickiest part is getting the spring compression tool lined up just right so the spring doesn't come shooting out like a bullet, just be careful and you'll be alright!
#8 | |
Yes it is!
Is the process the same on a SBC? My truck smokes a little when you first start it up or if it has been idling for an extended period of time. The truck sat for 10 years without being started once. It has 83,000 miles on the truck and original 305.
And congrats on your success story!
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB |
#10 | |
It's the same! My 454 didn't smoke at start up but did if idling for a while so I'd think you're issue is the valve seals and not the piston rings!
#11 | |
I don't plan on doing the other valve seals until they go bad simply because I believe in the old saying, "Don't Fix It If It's Not Broke"!
#12 | |
#13 |
Only one cylinder was oil fouling the plug, #4.
This is what it looked like before replacing the valve seal! ![]() |
