Old 03-04-2012, 11:09 PM   #1
jtp67-72
jtp67-72's Avatar
Need measurement crank pulley to timing cover!!
Anyone got a f-body crank pulley installed ?? need a measurement from back edge of crank pulley to timing cover--I have a truck one now and can't get an accurate measurement of difference from any photos I have seen--Trying to drop my 6.0 lower in the P.B. dropmember-will be running the f-body pulley soon but need to lower now --- Thanx in advance...........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 03-05-2012, 10:59 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Need measurement crank pulley to timing cover!!
There's not really a good spot to get a measurment, so I measured both a truck and F-body at the same spot. The F-body measured 1 5/8" from the cover and a truck measured 2 3/8", so F-body is 3/4" closer. Hope this helps.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-05-2012, 11:22 AM   #3
nibs
JRods Garage
nibs's Avatar
You wont be able to run the F-body accessories with a dropmember. As it sits, from PB, the alternator wont allow for lines to be run on the rack and pinion. Then, you wanting to drop it even more I dont see it working at all
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 03-05-2012, 09:37 PM   #4
jtp67-72
jtp67-72's Avatar
I'm running the front runner setup which uses the f-body balancer-just didn't have it in front of me and Nate is making me some new truss supports which will lower engine 3/4"--needed measurement to make sure back of pulley would sit down in front of rack with new drop................thanx jim
Old 03-05-2012, 09:38 PM   #5
jtp67-72
jtp67-72's Avatar
That was exactly what i needed---thanx much.............jim
