Old 03-05-2012, 01:40 AM   #1
osaltyone
osaltyone's Avatar
c20 cab
Is the C20 cab the same as the C10? looking to swap my 84 c10 cab for a 75 C20 cab, but wanted to make sure it fit before purchase.
osaltyone is offline   Reply With Quote
Old 03-05-2012, 07:47 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: c20 cab
The cab is the same from C10-30 as long as you pay attention to the transmission hump. All 4x4's and 2wd 4-speeds got the large transmission hump, and your carpet will be different if you don't have the high hump. This can easily be bolted or welded in from your previous cab though. The next problem you'll have is trying to use an 80's front clip on a 70's style cab. You'll need to cut holes in the firewall for the hood hinges, and the wiper posts will need to be modified. I'm sure there are some other things I forgot to mention.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 03-05-2012, 01:22 PM   #3
osaltyone
osaltyone's Avatar
Re: c20 cab
Thanks! Sounds like too much work, not worth it.
