Ignition switch
Quick Question. I'm fighting a no start problem in my 67 has a 350 out of a 86. After replacing cap rotor coil and module and still not getting any spark I'm thinking it might be the switch. Was wondering how it comes out of the dash. Any help is greatly appriciated
![]() Join Date: Aug 2007
Re: Ignition switch
I have a couple of them that work and are in great shape if you need to replace yours, to remove it first remove the ket, you will need to place a small wire, I use a paper chip into the little hole on the left side of the key, then push in and turn to the accessory position and the lock will come out. Next tap on the three notches on the bezel, counterclockwise to loosen it, then spin it off and the rest comes out from behind the dash, let me know if you need to look at one, its a bit tricky but easy once you have do it a few times.
Good luck
Scotts72C10 |
Re: Ignition switch
Thanks Scott I'll let you know tomorrow if I need oneof them.
#4 | |
The Older Generation
Re: Ignition switch
FIRST, insert key and turn it to the left as far as it will go. THEN insert a wire, small allen wrench, or straightened paper clip (the large ones work best) into the hole in the face of the lock cylinder and "gently" depress the retainer pin. With the pin depressed turn the cylinder further to the left. After it starts turning you have to remove the wire from the hole or it will bind. After you have it turned to the left as far as it will go wiggle it a little as you pull on the key to remove the lock cylinder. LockDoc
Re: Ignition switch
What if you have tried all of the above, and you can't get the d**** thing out? Is there a way to just use a BFH and fix it all later? My key is so worn, it will barley turn to acc, and when it does it is completely by accident. Hep! I spent $50 getting a new matched key and lock set for all the doors and ignition and glove box, but can't use them. Getting frustrated with it.
Thanks! Patrick |
#6 | |
Re: Ignition switch
http://67-72chevytrucks.com/vboard/s...d.php?t=462981 Have a new key cut from the code number and it should work correctly. If you can't find a locksmith to cut a key by code in your area PM me. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-05-2012 at 01:18 PM. |
#7 | |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Ignition switch
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#8 | |
Re: Ignition switch
LockDoc
I am a Referee of life.
Re: Ignition switch
I have to disagree.Mainly because I have never seen Leon treat anyone as other than a friend(meaning he acts more like he's helping a friend than a stranger) here on the BB.Still a great gesture and Leon is a top notch guy.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: Ignition switch
Thanks for the replies. I won't be able to get to it till this weekend. Crossing my fingers it will fix the problem.
#11 | |
Re: Ignition switch
I had all kinds of wierd issues until I noticed that on my rig. A new plastic plug from one of the suppliers and a little splice work made them all go away.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: Ignition switch
This is a good thread! I too am having issues with my ignition sw, when I go to start the engine, on the odd occasion it will start then die. Or if I wiggle the key while it is running I can get the engine to cut in and out or die all together.
Can I get a new ignition switch keyed to my door key? Does anyone have any recommendation on where to get a new ignition sw? Thanks!
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
#13 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Ignition switch
Your ignition switch gets it's power from the fuse box.
The fuse box gets its power from the forward lamp harness. The main power wire will be the large red wire that comes out of the end of the harness on the right sidebehind the battery. That wire is supposed to be a fusable link. It may have gone bad. It should be bolted down to the right front fender lug next to the battery. Either check to see if you have 12 volts coming just beond the fusible link or check it at where the wire plugs into the back of the fuse panel on the firewall. If you have power there, then the problem could be the starter switch. Before you change the switch you need to rule out the wireing between your fuse panel and your starter switch. To do that check to make sure the big red wire going into the back of the starter switch has power. It should have power all of the time, not just when the key is on. If you have power there then the switch is the next in line to be tested. With the key in the "Start" possition test the purple wire plugged into the back of the ignition switch. You should have 12 volts there. That is your starter wire so there is only power there when the key is in the start possition. (If no power to the purple wire, then you have a bad starter switch) If you have 12 volts there, then test the purple wire in the engine harness where it plugs into the fuse panel on the engine side of the firewall. This will take a second person, unless you have unusualy long arms..lol If you have power there with the ignition switch in the start possition, then test the purple wire it hooks up to the starter solenoid. If you have power there and your engine still doesn't turn over you may have a bad starter solenoid. If I missread the post, then disreguard this message... ![]()
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#14 | |
Re: Ignition switch
LockDoc
#15 | |
Re: Ignition switch
I poked the little wire in there, felt the springy latchy thing and turned the cylinder to the left a little. It only went to about 11:00 or so (I've got a '67). I tried and tried to wiggle the cylinder out with no luck. Applied a little blaster and wiggled some more, tried some o-ring picks, still no luck. Then....idea! I backed out the chrome ring that I was trying to get off in the first place and it "pulled" the cylinder out of the body. Thanks again!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#16 |
Re: Ignition switch
Yes, very well written! Thanks for the help LockDoc.
#17 | |
Re: Ignition switch
Thanks guys. Glad I could help. LockDoc
#18 |
Re: Ignition switch
I am a bit unsure, do you have no spark or is the engine not turning over when you try to start it? The conversation seems to have gone toward the later but your initial post makes me think it has no spark to plugs.
If its no spark to the plugs, i cerainly would not start by taking the ignition switch out. If the truck is turning over you are getting 12volts to the switch. Now whether you are getting 12v keyed power to the coil balast resister is another matter. By memory I cannot remember is there is dedicated keyed power for ignition or not but to test this is very simple. If its still points when the ignition swith is on it should have 12 volts to the balast resister under the hood or 12 volts strait to the HEI. If you are getting 12 volts to the balast resister or HEI plug on the distributer then your problem lies after that not before. Also you should only get 12 volts to one side of the balast resister, The side going to the coil is lower, I am not sure since i went HEI so long ago but i think around 8-9 volts. I would probably run a jumper from the battery to the resister and see if I got spark as a test. If you get spark it is save to run it this way but be aware you will have to remove that 12 volts to kill the engine. If I didnt get spark i would run it to the coil directly, Just dont turn it over very long to the coil like this or it will damage it, and do not run the engine this way. If you get spark on this scenario then your coil and points and such are working and you need to look at the 12volt supply to the coil or possibly a bad balast resister. If not you have a problem with coil or distributer. If its not turning over, then disregard all of the above. |
