how do you jack up the front?
just wondering the correct or different ways to raise the front with a floor jack and then leaving it on jack stands.i finally got some and a floor jack after years of bottle jacks and wood blocks.
" Never look up a dead dogs butt." ![]() |
Re: how do you jack up the front?
That all depends on the tonnage of your floor jack, on mine I just put the floor jack in the center of the front cross member and jack it up until both tires clear, then I put the jack stands at both ends of the crossmember and lower the truck on to the jack stands.
Slots go on anything!
Mine is so low (and I haven't sprung for a low profile jack), so I have to lift one frame rail, set a stand under it, then get a floor jack under the crossmember. Then I can lift the whole front and put stands on both sides.
1974 Jimmy- 5.3/4L80e/NP241 |
Gentleman Jim Driver
I lift mine using the cross member and put the jack stands under the lower control arm cross shafts.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#5 | |
Then this.
John 82 Chevy Silverado 350ci/TH350 ![]() |
i lift mine from middle cross member too, but I place jack stands under frame rails on each side under door area...very sturdy. Same for back, jack under diff and stands on frame rail just further back.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
This. the frame torque boxes are at this point, strongest place to put the stands.
First I take the foot off the jack, then I yell for my wife till she comes outside to see if the truck fell on me, when she gets outside I get her to push the jack under the crossmember while I lift the truck by the front bumper
J Knight's way is much easier but my way is more fun
What Hump?
This is where I place my stands also, I then throw the tires and wheels I take off under the vehicle - this saved my life one time when the car fell off the stands while I was under it, yes I was really skinny!
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
LOL
my jack fit under rear pumpkin o.k.but,the front is lower.i used to jack up one side then wood blocks under the frame.now,i'm high tech with floorjack and stands.i'd use a solid old fir 8x8' blocking....as eyegore said,this is no joke .alot of people have died from getting their chest crushed.whatever you do.do it safe.
#13 |
I have done the same thing lol
#14 | |
#15 |
That's how I did Jonboy's 74 & that's how my dually is currently sitting in the driveway.
#16 |
Yeah i use a jack and jack stands both i don't trust a jack alone i had one let go on mine while i was taking a trans out,Lucky i only hit my foot and i wear steel toe boots lol.
#17 |
What Hump?
Glad we both can laugh about it. Then there is the idiots that use masonary blocks to hold up a truck, I mean they stand it on end. They have never seen a block crumble.
#18 |
#19 |
What Hump?
Yes that was harsh, but I knew a guy who died that way.
#20 |
Drag Racer
mines the exact same way, except i dont have a wife i just have my friends help me, heres an idea of how low my front end sits
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
