03-05-2012, 05:13 PM | #1 |
Help identify 71-72 and 73-87 steering parts?
Picked up this frame a few days ago... It is a 69 frame that has been converted to 5 lug with front disc. I've been trying to figure out how the previous owner did the front disc conversion so I can buy some parts for it. Looks like a 71-72 set up to me???
03-05-2012, 05:14 PM | #2 |
Re: Help identify 71-72 and 73-87 steering parts?
I have not had any luck with the casting #'s on the calipers and spindles. The person I bought it from had purchased it just for the motor and trans he got with it. He had no specific information about anything that has been done to it.
03-05-2012, 05:27 PM | #3 |
I can say the uppers and lowers on my '86 don't look like that.
03-05-2012, 06:58 PM | #4 |
Thanks! I didn't think they did, but what confuses me is there are welded tabs for the brake hose on the front of the crossmember. I didn't think you had to do that unless you swapped the whole crossmember out....
03-05-2012, 10:54 PM | #5 |
67-72 parts collector,…
The only way to know which spindle that PO used,... is to determine which upper ball joint or outer tie rod you have.
The later 71-72 and 73-87 balljoints will press into and bolt into the 63-70 a-arms.
03-06-2012, 01:36 AM | #6 |
What would be the easiest way to determine this? Buy a tie rod end for each and see which one matches up?
03-06-2012, 07:42 AM | #7 | |
The parts store might not stock the 71-72 stuff. Another way to tell is if you have the light duty 1" rotors. These are a 73-87 ONLY design. If they are the 1.25" wide rotors,... then you will need to check with parts listed above.
03-06-2012, 10:47 AM | #8 |
They are the 1.25" wide rotors, so I will go ahead and get the 73-87 outer tie rod and check it out. Thanks for all the help guys!
