Old 03-05-2012, 06:46 PM   #1
Blackholebob
Big block brackets and pulleys
Name:  9302011 037 (640x360).jpg
Name:  9302011 041 (640x360).jpg
Name:  9302011 041 (640x360) (2).jpg
Name:  9302011 042 (640x360).jpg
Name:  9302011 044 (640x360).jpg
In honor of the big block they came off of $402.00 plus shipping for the entire set of brackets and pulleys.They have all been blasted and powder coated.I also have the power steering pump and reservoir if interested.I would like to sell as a package right now.I will take pay-pal or P.O. money order.Thanks: Bob. Pay-pal- blackholebob@verizon.net
Blackholebob is offline   Reply With Quote
Old 03-07-2012, 04:22 PM   #2
Blackholebob
Re: Big block brackets and pulleys
Midweek bump.
Old 03-11-2012, 03:05 PM   #3
Blackholebob
Weekend bump.
Old 03-14-2012, 01:21 PM   #4
Critterman71
Critterman71's Avatar
I will take the whole set up DO yo have the crank pulley as it is not in the picture? and do you have any bolts?
Critterman71 is offline   Reply With Quote
Old 03-14-2012, 01:27 PM   #5
Blackholebob
I will double check that pulley.Thanks Bob
Old 03-14-2012, 01:37 PM   #6
Blackholebob
Critterman I see now I had two pics of the inner crank pulley 2 groove.I also have the outer single groove pn. 3925525BR.
Old 03-14-2012, 04:59 PM   #7
Classic Bowties
Always on the hunt...
You may want to check out the #4 pictured P/S pump pulley also, it could just be the picture but it looks alot like a 3325 S/B pump pulley to me. The BBC P/S on the pump pulley should end in 5537, and should be paired up with a 5525 outer crank drive pulley. Mel
Classic Bowties is offline   Reply With Quote
Old 03-14-2012, 05:02 PM   #8
Critterman71
So let me get this straight you have the 3 grove (2pc) crank pulley and the 2 grove fan pulley, and the 1 grove power steering pulley. The alternator brackets (2pcs), the power steering brackets ( 2pcs) and the A/C brackets (9pcs) all with no bolts. I will take it as I said I would if this is correct. On the the Power steering pump and res. set up is it dent free and coated the same? I need to get shipping on it to 48872 as well. I have the unit price per your PM. I PMed you as well before I reread the post so most of this is the same. I apologize for the confusion
Old 03-14-2012, 06:07 PM   #9
Blackholebob
Critterman:OK Let me post the pulley no.s for you.I want you to know everything you're getting.There are no bolts I seem to have lost them.
PS- 3860457CV, from what I can Find this is correct. As I said everything came off the original motor.
Inner 2 groove crank pulley-3874414 BO
Outer single groove crank - 3925525 BR
Water pump 2 groove - 3927789 AG
The pump and reservoir are not coated, they were only cleaned up.If you want pics. let me know.Thanks again. Bob
Old 03-14-2012, 08:32 PM   #10
Critterman71
Thanks Everything looks good. I would like picks of the other parts and overall condition any dings dents splits? Thanks. To bad on the bolts oh well that's why there is this forum to find stuff. any one with the correct bolts out there???
Old 03-14-2012, 10:06 PM   #11
Blackholebob
Here are the pics of the power steering stuff.
Old 05-11-2012, 11:39 PM   #12
Blackholebob
These are back up for sale as I haven't gotten any response from Critterman71.The power steering pump,resv., and hoses are 75.00 plus shipping.
Old 05-14-2012, 06:56 PM   #13
Blackholebob
Ttt
Old 05-18-2012, 08:55 PM   #14
Blackholebob
Weekend bump.
