Old 03-05-2012, 08:50 PM   #1
C15_Sierra
C15_Sierra's Avatar
Exclamation Oil Filter Question
I've run my 5.3 swap a few times in the driveway for a few minutes at a time, and never had problems until I got to the exhaust shop. After we unloaded the truck, I started it up again to put it in the right place. That last time I ran it, the oil filter started spewing oil. At least I think its the oil filter because that was the only thing dripping when we shut off the motor.
The place was closing soon, so we took the time to clean up and I pulled the oil filter to check and see if it was double gasketed by mistake. Not the case. I did put the filter on as tight as I could by hand, and it was only later that my buddy mentioned that friend of his, who is also a dealer tech, puts the filter on his 6.0 with a wrench, which I've always thought has been a no-no. Are these engines an exception to the rule?
Am I just a massive idiot for putting the oil filter on not tight enough, or do I have a bigger problem? I'm confused as to why it happened after I ran it a while. The filter wasn't junk - I used a stock ACDelco filter.
I plan on going back there tomorrow with a fresh filter and oil to see if I can get it resolved. Anyone have any other suggestions?
Thanks!
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 03-05-2012, 09:37 PM   #2
TR65
TR65's Avatar
Re: Oil Filter Question
I just use the 3/4 - 1 turn standard on my 6.0 but I always use the filter wrench to do it.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-05-2012, 09:49 PM   #3
463
463's Avatar
I think after the filter gets tight by hand 1/2 to one turn more is normal.
You should be ok to tighten and check. Who knows the filter may be flawed.
On a oil change i wipe the filter contact area clean then put a very light film of oil on the filter gasket and reinstall, and then snug it nice. Good luck
Trueman
463 is offline   Reply With Quote
Old 03-05-2012, 10:36 PM   #4
mooseknuckles
mooseknuckles's Avatar
when you took the filter off was it tight??
mooseknuckles is offline   Reply With Quote
Old 03-05-2012, 10:38 PM   #5
ls1nova71
ls1nova71's Avatar
I never put them on with a wrench, only hand tight and have never had a problem. I have seen claw type wrenches put small holes in the filter and cause leaks. Did you take off the bypass above the filter? Maybe it's leaking there?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-05-2012, 10:47 PM   #6
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Good and hand tight is all I have ever done. Maybe it was the block off above the filter.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-05-2012, 11:55 PM   #7
C15_Sierra
C15_Sierra's Avatar
It was hand-tight when I put it on...the bypass plate was another idea that came about after the fact. Gonna check that in the morning...Thanks!
-Steve
Old 03-06-2012, 01:06 PM   #8
C15_Sierra
C15_Sierra's Avatar
Checked this morning and no signs of leakage on the bypass plate. Tightened on the new filter, filled 'er up, and it ran without puking everywhere...so now she's on the lift getting her new exhaust put on!
-Steve
Old 03-07-2012, 04:24 PM   #9
463
463's Avatar
Good to hear!
Trueman
