Old 03-06-2012, 12:16 AM   #1
slinginrods
slinginrods's Avatar
rear end width
any body know the rear end width on a stock 2wd ,short box 83? i want to stuff some fat tire under the back and have access to a 56" wide rear ,measured from wheel mounting surface to wheel mounting surface.
slinginrods is offline   Reply With Quote
Old 03-06-2012, 12:40 AM   #2
dustnx
dustnx's Avatar
Re: rear end width
I'd like to know this too, I have access to a 62" wide with disc brake setup out of a 89 transam. Curious if anyone else has tackled anything of this sort.
dustnx is offline   Reply With Quote
Old 03-06-2012, 04:58 PM   #3
jhngardner367
jhngardner367's Avatar
Re: rear end width
The hub-to-hub distance is 67". The distance between spring centers(leaf springs),is 42.5"
The trans am rear end would have to be modified,and may still be too light duty to work.
It may fit on the trucks that have coil spring rear end ,but it would still take some work.
Usually,fittingwide tires calls for tubbing the bed,modifying the frame,and flaring the wheel opening,even with a 4-arm trac setup.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-06-2012, 08:23 PM   #4
slinginrods
Re: rear end width
Guess ill be using the 9 inch I have out of an f 150
Old 03-06-2012, 08:35 PM   #5
killerpickup
Re: rear end width
I USED A 9 INCH CUT DOWN TO 60 INCHES, THE INSIDE BED MEASUREMENT WAS 80 INCHES. i TLEFT ME ROOM TO TUCK 10 INCH WHEELS WITH NO PROBLEM.
killerpickup is offline   Reply With Quote
