Old 03-06-2012, 12:47 AM   #1
nwfy
1963 chevy s/b f/s 2wd to 4x4 frame
tried to take the box from my 2wd truck and bolt it to the frame of my 63 4x4 but the bolt holes do not line up. not even close . i believe i know how to solve the problem..... any body else run into this issue
nwfy is offline   Reply With Quote
Old 03-06-2012, 12:56 AM   #2
Slow Build
Slow Build's Avatar
Re: 1963 chevy s/b f/s 2wd to 4x4 frame
If the 2WD is a 60-62 the frame width is different.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-06-2012, 01:01 AM   #3
nwfy
i do believe both trucks are 1963 one is chevy the other gmc....the one i removed the box from[2wd gmc] has no vin tag so perhaps it was a 62....hmmmmmmmm
Old 03-06-2012, 01:13 AM   #4
70cst
70cst's Avatar
Good possibility because I would think the same yr beds would line up,
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-06-2012, 01:57 AM   #5
Captainfab
60-66 Nut
I would say that either the bed is from a '60-'62, or your frame is a '60-'62. An easy way to tell, is the 2wd '60-'62's had the torsion bar front suspension. If the bed mounting brackets on your 4x4 frame are wider than the holes in the bed, then your frame is a '60-'62.
