Old 03-06-2012, 01:26 AM   #1
dantimdad
dantimdad's Avatar
remove column shift linkage?
My truck was converted to a 5 speed before I bought it. I am in the process of body work and cleaning up any unnecessary stuff.
My question is: Can you remove the 3 speed linkage from the column without something bad happening? If so, how?
Thanks,
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 03-06-2012, 07:05 PM   #2
hugger6933
Re: remove column shift linkage?
I have a column out of a chevy van that I ground down the shifter bowl so that it was smooth and then welded the shifter arm to the housing at the bottom where the linkage goes,now it looks just like a factory floor shift tilt column
hugger6933 is offline   Reply With Quote
