Old 05-03-2003, 12:49 PM   #1
biddaboy
biddaboy's Avatar
Smile Front crossmember swap
When swapping a 73-up crossmember into a 69 are the frame widths the same or do you need any type of shim to bolt it in.Thanks for any info biddaboy
biddaboy is offline   Reply With Quote
Old 05-03-2003, 08:52 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
The widths are the same.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-03-2003, 08:54 PM   #3
phantom dually
There may be a diffrence or two with the way the bolt holes match up. Alot of people say to make sure you get everything from the donor to do this swap.
Old 05-03-2003, 10:33 PM   #4
kaycee
kaycee's Avatar
There are only 2 bolt's that need to be a little larger other than that direct bolt in easy 2 do.And yes take everything from the donor
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is online now   Reply With Quote
Old 05-04-2003, 10:56 AM   #5
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
why would you do this?
1968 GMC 910 Long Step 250/3onTree
1969 Chevy C10 longfleet, 350/350
68_GMC_910 is offline   Reply With Quote
Old 05-04-2003, 11:58 AM   #6
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Disc brakes, and cheaper drop spindles amoung others.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 05-05-2003, 07:19 PM   #7
phantom dually
Cause its fun too!!
Old 05-06-2003, 12:15 AM   #8
biddaboy
biddaboy's Avatar
Thumbs up
Thanks for the info you guys are great .biddaboy
Old 03-31-2004, 12:48 AM   #9
72c5
72c5's Avatar
And what about if you are going from a '69 leaf spring 4wd blazer to the '73 IFS front subframe? Still only the 2 holes to enlarge?
72c5 is offline   Reply With Quote
