Old 03-06-2012, 08:42 PM   #1
rudy350
Unhappy leaf spring hangers 1965
i really dont know what o do,, i need all four leaf spring hangers on my 1965 gmc truck.. the ones i have are 75 % rusted .. i really need help with this i have everything ready for my truck but this and its killing me
i cannot find none no were any body know something about them >>>>
rudy350 is offline   Reply With Quote
Old 03-07-2012, 12:14 AM   #2
rcbildr
rcbildr's Avatar
Re: leaf spring hangers 1965
Can you post some pics of what they look like.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 03-07-2012, 01:00 AM   #3
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I wish I would have kept mine. My truck had leaf springs and I switched back to trailing arms so it was easier to bag. Cant see why you cant search a you pull parts yard and find something you can make work??
[IMG][/IMG]
[IMG]<a href="http://s561.photobucket.com/albums/ss54/motoimpaired558/Truck%20Build/?action=view&amp;current=IMAG0294.jpg" target="_blank"><img src="http://i561.photobucket.com/albums/ss54/motoimpaired558/Truck%20Build/IMAG0294.jpg" border="0" alt="Photobucket"></a>[/IMG]
MOTOIMPAIRED is offline   Reply With Quote
Old 03-07-2012, 01:37 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Why couldn't one use newer model hangers?
Like 73-87?
66 C20 Service Truck:
Old 03-07-2012, 02:12 AM   #5
Captainfab
60-66 Nut
That might be the best idea for the OP. However I told him to post a WTB in the '60-'66 classifieds, so we'll see if someone happens to have what he needs.
Like 73-87?
Old 03-08-2012, 09:34 PM   #6
rudy350
thanks guys for the help but as we speak im making my own im crossing my fingers theyll turn out good .. lol
Old 03-11-2012, 02:52 PM   #7
rudy350
Ok I fab my own hangers.. But one question should I use the leaf springs and shakles from the 77" donor ? On the gmc it had 9 leafs and the donor only 4.. So what should I go with ??? Should does 4 drop my truck lower?
Old 03-11-2012, 05:39 PM   #8
Captainfab
60-66 Nut
WOW! those look very nice Quite beefy!
Well that would depend on whether the '77 shackles and springs will work with your new rear hangers and the original front hangers. I would think the '77 springs might give you a smoother ride, but I have no idea on any change to the ride height. if you can compare the two side by side that will give you some idea on the ride height question. Although, the actual spring rate will play a part in that.
Old 03-11-2012, 07:02 PM   #9
gimmy 64
the early gmc's leaf springc are 2 1/4 wide and the newer truck springs are 2 1/2 wide i think they changed in 71?
gimmy 64 is offline   Reply With Quote
Old 03-12-2012, 01:56 AM   #10
LostMy65
LostMy65's Avatar
Great Job on the Hangers
Old 03-14-2012, 06:26 PM   #11
rudy350
Thanks guy well I spent alot of time on the enless measurements lol lol.. But they will fit the 77 leafs. The original 65 leafs had 9 ,and the 77 has 4 and the shakles are smaller than the 65 gmc.. Can yall tell me were I can find out what rear end I have.. Its the 77 donors... And check out what just came for the xmember 77 donors. Can u spot what summit gave me in the box
Old 03-14-2012, 06:34 PM   #12
rudy350
Old 03-14-2012, 06:39 PM   #13
rudy350
Old 03-14-2012, 06:43 PM   #14
rudy350
Old 03-14-2012, 06:58 PM   #15
rudy350
Talking Re: leaf spring hangers 1965
in the left before all rusted out, and on the right the beefier version
Old 03-15-2012, 12:29 AM   #16
Captainfab
60-66 Nut
Is Summit trying to tell you something about installing those bushings?
Somewhere here is a list that should tell you what you have by the stamped code on the passenger side axle tube. if it were me, I would pull the rear cover and have a look. The rear differential is one of the most neglected parts for maintenence. The gear oil most likely needs changed. It will only cost you 2 quarts of 80W90 gear oil and a cover gasket. Then you will know exactly what gears you have, and have peace of mind that your differential has fresh oil.
Old 03-15-2012, 12:44 AM   #17
trevrolet65
Summit five hour racing, your gonna need it, lol. Yeah if that thing has been condisating, check for rust on the pinion while your counting the splines. Emory cloth and elbow grease if not too bad, and some new gear oil for sure.
trevrolet65 is offline   Reply With Quote
Old 03-15-2012, 12:57 AM   #18
trevrolet65
My 71 has 4 leaves.
