Old 05-03-2003, 05:19 PM   #1
robby
Semper Fidelis
robby's Avatar
clutch pivot on 400 sb
I just checked out the motor in my 79 k20 that I am going to part out on the advice from a board member because I asssumed that I could put it in my 72 K10 with a four speed. Well lo and behold the block has a boss for the pivot but it is not drilled and tapped for it. Question is can I drill and tap it successfully or is it not worth the hassle? I need to find a flywheel for a 400 anyway. Maybe I should fix mine or find another 350 for my K10-Thoughts?
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 05-03-2003, 06:26 PM   #2
lpaine
lpaine's Avatar
You can drill and tap it, but it's a lot easier with the engine out- which I assume you're doing anyway. I'd say it would be a simple enough 2 or 3-beer-job.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 05-03-2003, 07:40 PM   #3
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
More than likely, you will end up drilling into the water jacket. If so, dont be alarmed, just make sure to seal the threads with a good sealant.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 05-03-2003, 11:27 PM   #4
robby
Semper Fidelis
robby's Avatar
so not a real high skill job? I will have it out of the truck.
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 05-04-2003, 12:31 AM   #5
spinning wheels
spinning wheels's Avatar
When I bought a 400 small block, (this was many years ago), to install in my 70 Z28. I found out that GM never installed a 400 small block with a stick. So, no flywheel was available. Since the motor is externally balanced, none of the other small block's flywheel would work, they are internally balanced. Hopefully you won't run into that problem. I mean, I hope you can find an aftermarket flywheel that won't set you back a whole bunch of bucks. I can't say that it has never been done, just not sure if its the best or most cost effective way to go.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 05-04-2003, 06:38 AM   #6
JimKshortstep4x4
Talking
I have a 400 small block installed in my 65 SS with a M 22. The bell housing that I am using has the clutch pivot tapped hole in it and for this application it works well.
Flywheels are available, I bought mine from Northern.
Jim
Old 05-04-2003, 10:21 AM   #7
robby
Semper Fidelis
robby's Avatar
I have another thread about the flywheel, basic consensus is that you can buy a flywheel for about $150 new. I think there are a few trucks in the 70's that might have had a manual tranny behind a 400. but I won't wear myself out looking for one. Thanks
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 05-04-2003, 12:36 PM   #8
robby
Semper Fidelis
robby's Avatar
Just looked up the 400 flywheel in Norhtern's web site-$109.
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
