03-07-2012, 09:52 AM | #1 |
Help with body mounting bolts
I am looking at a 1972 short bed fleetside that the p/o said has been in storage for more than 15 years. Apparently the body has been taken off of the frame at some point to start a restoration and somehow the body mounting bolts can't be found for whatever reason. I need to know what size of bolts to purchase so that the body can be put back on the frame in order to transport it. I need cab bolts, bed bolts, and core support. Any help is much appreciated, thanks.
03-07-2012, 07:03 PM | #2 |
Re: Help with body mounting bolts
Ok I know its more info than you asked for but heres a cut & paste of the bolt info for Blazer / Jimmy / 1/2ton 2wd truck & 3/4ton 2wd 1/2&3/4ton 4X4 bolt lengths for Cab, Rad & Bed mounting
I figured as soon as I posted just 1 everyone would be asking for the others so I'm giving them all. Radiator Support: 7/16"-13 x 3.375" carriage bolt 67-72 Blazer Body Mounting Hardware Sizes Body Mount #1: 9/16"-12 x 5 1/2" hex head cap bolt Body Mount #2: 3/8"- 16 x 10" Carriage bolt Body Mount #3: 3/8"- 16 x 5.5" Carriage Bolt Body Mount #4: 3/8"- 16 x 4.5" Carriage bolt Body Mount #5: 3/8"- 16 x 5.5" Carriage bolt 3/4 ton, 1ton 2wd & All 4X4 Cab Mount Bolts Front bolt 2- 9/16"-12 x 6" hex head cap bolt, 4- 9/16" large Diameter flat washers, 2- 9/16"-12 Nuts Rear bolt 7/16"-14 X 8.5" 1/2ton 2wd Cab Mount Bolts 1/2 ton 2wd Front Mount bolts- 9/16"-12 x 6" hex head cap bolt 1/2 ton Rear cab mount bolts, 7/16-14 x 6", hex head bolt Core support bolts, 7/16-14 x 4", carriage head bolt Sleeve Outside Dia. Inside Dia. Length 73-87 Bed Bolts 8- 1/2"-13 X 4 1/2" Carriage bolts 67-72 Door Hinge Bolts 3/8-24 X 1 1/4" We also sell these as kits for those that just want to order them instewad and for the guys buying Cab & Radiator support bushing kits from other suppliers and are finding they do not include new steel spacer sleeves we also have those invidually or in our kits except for the large rear spacer sleeve found on the rear mount of the 3/4&1ton 2wd & all 4X4 we do not have this one available. Paul Jr @ GMCPauls Last edited by GMCPaul; 06-16-2020 at 01:13 PM. |
03-08-2012, 08:56 PM | #3 |
Thank you Paul Jr for the information, very much appreciated. I ended up purchasing the truck in question, so i feel that another road trip is in my future to puchase a bolt kit from you, thanks again.
12-04-2012, 12:33 AM | #4 | |
Are you still selling those bolt kits? If I am looking for a bolt kit for a 1971 K5 Blazer (4x4). Is the kit all inclusive? (IE will I need to buy anything else besides the actual bushings).
Gary 1971 K5 Blazer 350 V8 |
12-04-2012, 09:42 AM | #5 | |
Paul Jr @ GMCPauls |
12-04-2012, 11:00 PM | #6 | |
Do you guys sell the rubber or ploy bushing kits? I think I am going to go with poly, as I have heard the rubber has a short life (I live in Northern VA--snow, rain, etc). Either way I am replacing everything on the mounting kit so at a minimum I am interested in the pricing of the steel sleeves. Thanks for the clarification. (also are the offset washers hard to find)
12-05-2012, 12:08 AM | #7 | |
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
01-25-2018, 07:46 PM | #8 |
Core support bolts, 7/16-14 x 4", carriage head bolt Is the difference there 67-68 vs 69+?
1968 LWB C20 / AC / Wood Bed |
05-21-2020, 09:19 PM | #9 | |
They are grade 5 they can be purchased at bolt depot. $0.70 each shipping was $4.95 Just a note for people looking for the bolts. |
