03-07-2012, 11:46 AM | #1 |
tranny crossmember
Ok so i just got the motor and tranny in the truck last night...5.3 4l60e....
Can i use the stock cross member that my tb 350 ? Or shoukd i just buy the one from ece Posted via Mobile Device |
03-07-2012, 12:26 PM | #2 |
Re: tranny crossmember
I used the stock 350 crossmember. It was in the very front holes and with the ECE motor mounts I mounted it just forward of the second set of holes, i.e. there are half a set of holes 2.75" back...I call the second set of holes the ones 3.75" back. You could probably use the second second set of holes and drill new holes in the crossmember if you use the ECE motor mounts.
I'm guessing if you use 1" back motor mounts the second set of holes would match up perfectly. Anyways, use your original crossmember and save the money...you just may need to drill a few holes. It's hard to explain all the holes without a picture...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
03-07-2012, 01:36 PM | #3 |
I get what ur tryin to say...i wont be able to work on thw truck until
friday ...ill try and post some pictures then Posted via Mobile Device |
