03-07-2012, 01:21 PM | #1 |
Rear tank side or bed fill?
I've got enough $ to get in on the Boyd's GB this week on the tank for my 72, but I don't know if I should use bed fill or side? How does the side one work? I know the bed fill is pretty self explanatory.
Thanks. Posted via Mobile Device
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
03-07-2012, 02:03 PM | #2 |
Florida Edition
Re: Rear tank side or bed fill?
You've got $$? Glad to see some of us do...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-07-2012, 02:11 PM | #3 |
Bed sides work welll too, just more work. Two common ways are,
1 Behgine the side marker light/reflector...It works, but is tight. If the stations in main have those big tubes over the pump nozels, it may not be the way to go. 2. Add a fuel door filler to the side. I put a fuel dioor fro an 88-98 C1500 into the side of my truck's old bed. Works good, but just a lof of work to make it look llike it belongs. Another option, like HuggerCST did, is fix up your fuel tube behide your taillight. It works good, but again a lot of work. Quickest and easiest is in the bed floor.
03-07-2012, 02:16 PM | #4 |
lol, brad. I had to pay some bills last month (oil bill $800.00 for 200 gallons!!!!) but i have enough to get the tank, sender, and some lines from Inline tube for the brakes. Then i'm tapped out again! lol
Thanks Palf70step. I don't have the ability or tools to go that route, so bed floor it is. lol
03-07-2012, 02:34 PM | #5 | |
I use my truck as a truck. I have a Blazer tank. When I finally get around to installing it I can't imagine putting the filler in the bed because I use the bed and may have stuff in there when I need gas. If I had a nice looking, not used as a truck truck, I'd do the bed floor or somewhere in the inside of the bed side. The reason there is I would want the cleanest looking outside of the truck. My opinions are worth what you just paid for them.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
03-07-2012, 02:46 PM | #6 |
Opinions are why i post it. I get so many ideas, its always super helpful. And i thank you for posting.
I will use my truck very little as a truck. Might haul a few small boats here and there for the shop, but i doubt i'll haul much. I have seen lots of bed fills with nice covers over them. And it is recessed enought to not be sticking up through. I'm guessing the BOYDS tanks dont stick up through the bed floor on metal floors. But i'm going to ask first. I am not a fan of the 88-98 side door fills on these trucks, i just don't think it fits. MY $.02 anyway.
03-07-2012, 02:48 PM | #7 |
Here's one in the side...square truck, square fuel door.
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
03-07-2012, 03:00 PM | #8 |
Well that doesn't look to bad.
03-07-2012, 03:15 PM | #9 |
I found some pics of the Boyds tanks. Anyone got a pics of how there bed fill is done?
03-07-2012, 04:45 PM | #10 |
I probably have no idea what I'm talking about......but how hard would it be to put the fill behind the license plate like on older cars?
03-07-2012, 06:15 PM | #11 | |
I had forgotten he did it and that could be a very viable option. http://67-72chevytrucks.com/vboard/s...d.php?t=423035
03-07-2012, 07:16 PM | #12 |
I can see the finish line!
I am going with the bed fill option. The tank is installed and I will be mimicking what Foose did (pic) on the overhaulin build. This is next on my build once the driver side rocker is done. I am with you, this spot is much easier to fabricate, and it is very close to the rear of the bed, so I don't see it being a problem getting access to at the pumps.
I am from Kennebunk, but now live in New Jersey. I think you are little further down Maine, correct? |
